Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-16-2006, 02:28 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
safe boost level T28 50 trim
Hey everyone. I was wondering where I should set my boost. Right now it is only at 15psi. I will soon be done installing my fmic from that group buy and I plan on turning it up. I was going to put it around 17psi but, I have heard it would be good up to 20psi safely. All my info is in my sig. Oh and I do have 650cc injectors but, they are NOT installed yet. I do have a fuel pump though. Any input would be awesome thanks.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 03-16-2006, 03:06 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: safe boost level T28 50 trim
You might it fuel cut without the injectors in. Try it out and see what happens worst case senerio you just turn it down a bit, I was running 18psi on stock injectors and I hit fuel cut really easily (5500-6k rpms)
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 03-16-2006, 03:28 PM
Whathits14 Whathits14 is offline
Your 650 injectors are just fine for the amount of boost you plan on running. The install is not that bad at all, but I would reccomend getting the upgraded lower seals for the injectors regardless. At 20psi knock will be your biggest concern, make sure you get a logger and keep the knock down. You wont hit fuel cut, just get a good tune and you should be good to go.
Need a GOOD 6-bolt engine?
http://www.totaljdm.com/?id=19334
'95 Talon Tsi
EVO III GT, supporting mods, not running
Brand new never opened, walbro 190LPH fuel pump for a 2g $65 shipped.
Old 03-16-2006, 06:46 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
If i was you i would invest in getting DSMLINK!!!!! I paid $605 for my ecu to get done and im just waiting to install it when i get my car back together.
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 03-16-2006, 06:53 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
I have a friend that has his evo16g set at 19psi witout fuel-cut. IIRC it happens around 2.5g/rev on the stock fuel system.
Old 03-16-2006, 07:08 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
stock injectors? I'd say keep it around 12-13. What's the point of potentially starving your motor of fuel? The 50 trim flows ALOT of air way too much for the stock injectors to handle.
now - 2000 civic
soon - 2002 is300
Old 03-16-2006, 08:53 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Yeah man, I would for sure keep it to 12-13 like crunchy said. Remember you will need DSMlink to control those 660's. Also, the t-28 isnt a 50 trim is it?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 03-16-2006, 09:01 PM
NateS's Avatar
Thanks everyone. Right now I am going to just keep my boost set at 15psi. I am waiting to get a fuel pressure regulator to install my injectors so I can adjust my a/f with the safc. After I install the FPR and injectors I will probably turn it up to 20psi. I already have a palm pilot with the logging software(just need to download it). Thanks again for the help.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 03-16-2006, 09:04 PM
NateS's Avatar
I can just use my SAFC for the 650cc can't I? And as for the turbo... the guy before me said the t25 was replaced with the engine/tranny rebuild. Funny enough he had no idea what the turbo was but, he was positive it has 50 trim installed. I posted some threads about helping me figure out what it is and as far as I found out and from what other people said it is a T28. The turbo is a Garrett/Mitsu turbo. If you want pictures here is a link http://www.cardomain.com/ride/839636/3 scroll to the bottom.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 03-16-2006, 09:20 PM
Talon69's Avatar
It looks like a T-28 to me, But one thing i wonder is can you run 660cc on a SAFC? You need DSMLINK i believe. Maybe not with 660cc im not sure. Im going with 880cc or higher since i just got my DSMLINK
Current Cars
Old 03-16-2006, 09:23 PM
Thor06's Avatar
Jizzed In My Pants
660's are pushing the SAFC. They cant tune that well past like 550s, 650s can get a runable tune, and anything past that is impossible. I would sell your pocketlogger and SAFC and put it towards DSM link. You could probably make it work ok on the SAFC, but you will have trouble tuning to the setups full potential.
Old 03-16-2006, 09:55 PM
NateS's Avatar
Okay, that is what I thought. I think as of now I will just use the pocket logger and the safc to tune it as good as I can. I will edventually end up getting DSM link though, but right now it is a bit more money than I have.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 03-16-2006, 09:57 PM
ez1286's Avatar
It was pretty cold hear at the time so that's probably why i hit it at 18psi.
Old 03-16-2006, 11:36 PM
The T28 and the 50trim turbo are very different. Which one do you have? The T28 looks exactly like the stock T25, but has a bigger compressor wheel. The 50trim is obviously bigger and capable of pushing alot more air. 660s are nearly impossible to tune with a SAFC2. You will need DSMLink or emanage or an AEM unit
now - 2000 civic
soon - 2002 is300
Old 03-17-2006, 09:07 AM
kjewer1 kjewer1 is offline
AF - Advisor
Remember that the trim of the turbo is not the size, just the ratio of some of the dimensions. You could have a very small wheel like a t28 be a 50 trim, just not "the" 50 trim
At any rate, the t28 is somewhere around the size of a 14b. I think the highest airflow I heard logged was something like 32-34 lbs. So you could treat it as such. 20 psi should be doable. I would just keep raising boost until it knocks or stops increasing in peak airflow.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
