Old 03-16-2006, 12:45 PM
Bolognabob Bolognabob is offline
87 S10 Blazer Fuel Problem
Ok, I've got an 87 S10 Blazer with a 2.8, with a fuel problem... Fuel pump is running good, fuel pump relay is new, pressure at TBI is 13 lbs. Continuity check on injectors checked good. Key off voltage at injector harness is .50 volts DC. There is no spray coming out of the injectors. it sporadically sprays, sometimes..... any clues??????
Old 03-16-2006, 06:11 PM
jackass#1's Avatar
jackass#1 jackass#1 is offline
Send a message via Yahoo to jackass#1
Re: 87 S10 Blazer Fuel Problem
could be clogged injector.
Old 03-20-2006, 05:32 PM
otay..... aint the injectors, changed em........ could it be the ecm??? spark is still good, good pressure....... or could it be the IAC?
Old 03-25-2006, 06:54 PM
they should take away my tools........... i'm such a freaking moron.... ok, got it fixed..... ya know, if the power wires going to the coil come loose a little bit, truck won't start.................... i hereby declare myself..... f ing loser.............
Old 03-26-2006, 06:22 PM
jackass#1's Avatar
dont be hard on yourself, the easy things are the hardest to catch.
Old 03-27-2006, 11:41 AM
Cam1959 Cam1959 is offline
Smile Re: 87 S10 Blazer Fuel Problem
"been there done that". I try to consider and check all easier to harder checks. like connectipons getting lose or corroded over time, or clamps getting loose.
1983 S10 4WD carbed 2.8L automatic w A/C
