Old 03-16-2006, 10:45 AM
bmorezcmunee bmorezcmunee is offline
Thumbs down 95 cav backfire 2.2L
my 95 cavalier 2.2L started to backfire out of no where. i replaced the spark plugs and it got a little bit better. but it still backfires and now it sounds like i have a performance exhaust even though the exhaust system is completely stock. when it first started backfiring, it was inside the engine and through the exhaust. now that the spark plugs are replaced, it only backfires inside the engine which leads me to believe that my cat is clogged. im going to replace the spark plug wires today and see if that doesnt fix the problem. does anyone have any thoughts?
Old 03-16-2006, 12:25 PM
CavRacer CavRacer is offline
Send a message via MSN to CavRacer
Re: 95 cav backfire 2.2L
Personally I would check your header and exhaust to see if it's got a crack in it. If there's a crack in your header it would explain your engine sounding considerably louder and it would also explain why the noise is coming from inside the engine compartment.
2000 Cavalier Z24 5 Speed
Performance Mods
AEM Short Ram Intake
Bosch Platinum Spark Plugs
Magnaflow Exhaust
Visual Mods
Blue Led Interior Glow Kit
APC pedals
Painted Interior (half done)
http://www.cardomain.com/ride/2306352/1
Old 03-17-2006, 01:59 PM
spyderman2005 spyderman2005 is offline
Or it sounds almost like the flex pipe right behind the headers has a hole in it which would make it sounds incrediably loud and might also cause some of the back firing just a suggestion.
