Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 03-16-2006, 10:28 AM
franzprincivil franzprincivil is offline
Thunderbird 1994 8 cylinders 4.6 engine
I have gas coming out of the muffler. I changed the valve cover gasket. I changed the fill filter and the pressure relief gas. I even change the 02 censors. I still have gas coming out of the muffler. What do you think that might be? Please respond as soon as possible...
Old 03-16-2006, 12:08 PM
JR Tigerstar's Avatar
JR Tigerstar JR Tigerstar is offline
Re: Thunderbird 1994 8 cylinders 4.6 engine
It could be any combination of the following -
Coil pack(s), spark plug wire(s), spark plug(s), fuel injector(s), catalytic converter(s).
Your best bet is to have your EEC read for any codes.
Old 03-16-2006, 07:34 PM
overl0rd overl0rd is offline
I would say its a bad injector or fuel pressure regulator. Are you sure it's gas coming out the tailpipe?
Old 04-02-2006, 09:43 AM
schellfischy schellfischy is offline
I would have to say make sure all of the exhaust valves are completely seated and the seals are intact. That means you would have to pull the valve covers to check the valves. Is it intermittant or constant flow of gas? Do you smoke? Just kidding. Also check the valve springs or hydraulic valve lifters. If the gas is coming out of the tailpipe, then it probably got there by being pushed out by one of the pistons before being able to be fired, almost like a backfire that didn't. I think you have a very serious, and potentially dangerous, problem. I wish you the best of luck. Do you know how the valve and piston systems work? Post your response and I can get back to you. Don't let the girl thing fool you! I know more about cars than most guys I know. I would rather fix it myself than take it to a shop (for more than one reason). Good luck! If you should figure it out, please make a post and share the cause with me and the others, I am certainly intrigued.
Schellie--Proud owner and operator of one awesome '94 lx 4.6 ltr V8!!!!
Old 04-05-2006, 02:24 PM
mtnman1942 mtnman1942 is offline
Had same problem. You probably have an injecter staying open. My computer was bad, and caused injector to fault to open. Cost me app. 400.00 about 3 years ago. I had a repair shop make the repairs.
