Go Back   Automotive Forums Car Chat > Chrysler > Sebring | Sebring Coupe | Convertible
Old 03-16-2006, 09:52 AM
MrRupps MrRupps is offline
How to Remove Sebring interior part
I have a 97 sebring lxi and i needed to remove and interior part in the back of the car. the part i needed to remove is the driverside rear inside panel. i need to now how to remove this section to remove a dent on the exterior. does anyone know
Old 03-27-2006, 02:31 AM
clifford235 clifford235 is offline
Send a message via AIM to clifford235
Re: How to Remove Sebring interior part
remove the back seat cushion by pulling up on it to remove the clips. Then remove the back of the back seat by removing the two nuts holding the seat belts in place. These also hold the back in place. Once these are gone, lift up on the back to unhook it from the top. Once the back seat is gone, remove the speakers. Remove the screws holding the molded sides in place. Remove the rocker panel kick plates to remove the push pin holding each molded panel in place.
that's it. If you need to go further, you'll have to remove the rear window mechanism and perhaps the convertible hydrolics too.
