Old 03-16-2006, 08:42 AM
drew300 drew300 is offline
hydroboost brakes
Has anyone turned off the engine while moving and tried the brakes?
I wondered what would happen if I lost the serpentine belt, so I turned off the engine on an empty road. I was going slowly, because I knew the steering would be tough.
There's no reservoir for pressure, like with vacuum brakes. Be sure your seat bolts are good before trying this!
P.S. I thought with the extra work the power steering fluid does, I changed the fluid in the reservoir several times over a few weeks. A litre is cheap enough.
And of course the serpentine belt was replaced.
Old 03-16-2006, 09:49 AM
Blue Bowtie's Avatar
Registered Offender
Re: hydroboost brakes
Actually, there IS a reservoir. There is a small hydraulic accumulator that will provide oil pressure for one, possibly two assisted stops in the event of a pump loss. It is plainly visible. You can test yours by turning off the engine in your driveway/garage, and applying the brakes several times. You should notice increasing pedal resistance as the oil supply in the accumulator is depleted.
Old 03-16-2006, 10:19 AM
Curious. As I said, I did it on the road. I found no assist with the engine off.
Any idea where this accumulator is?
Thanks
Old 03-16-2006, 10:28 AM
Registered Offender
Your's should be in a similar location (yellow arrow):
Old 03-16-2006, 11:57 AM
Thanks, I have some home-work this wekend.....
