Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 03-16-2006, 08:32 AM
rockntommy rockntommy is offline
91 Blinking air bag light?
91 Grand Marquis and yesterday the airbag light starts blinking.
What is the deal?
Thanks!
1975 MG Midget
1985 300ZX
1991 Mercury Grand Marquis
Old 03-20-2006, 01:04 AM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Re: 91 Blinking air bag light?
What is the deal?
Thanks!
How many times does it blink and then pause?
You may need a new clockspring kit.
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
Old 03-20-2006, 11:43 AM
It blinks 5 times ( I think) I will double check.
What is a clockspring kit?
Thanks
1975 MG Midget
1985 300ZX
Old 03-21-2006, 08:24 AM
Correction...Blinks 6 times.
1975 MG Midget
1985 300ZX
Old 03-25-2006, 12:25 AM
Stevo2's Avatar
It's the part under the steering wheel which controls the electrical functions of the air bag, cruise control, horn, etc. gotta disable the air bag, remove the steering wheel and follow the instructions in the kit. Can only get the kit from Ford. About $100. Replaced the one on my 91 for the same code..all better now.
Air Bag Driver's Side - Intermittent Fault Codes 6/32
9214ford01
Article No.
92-6-1
March 11, 1992
^ AIR BAG - DRIVER'S SIDE - INTERMITTENT FAULT CODES "6 AND 32" DISPLAYED - VEHICLES BUILT BEFORE 12/1/91
^ RESTRAINT SYSTEM - DRIVER'S SIDE AIR BAG - INTERMITTENT FAULT CODES "6 AND 32" DISPLAYED - VEHICLES BUILT BEFORE 12/1/91
FORD: 1990-92 CROWN VICTORIA, MUSTANG, TAURUS, TEMPO
LINCOLN-MERCURY: 1989-92 CONTINENTAL1990-92 GRAND MARQUIS, MARK VII, SABLE, TOPAZ, TOWN CAR
LIGHT TRUCK: 1992 AEROSTAR, ECONOLINE
This TSB article is being republished in its entirety to include 1989/90 Continental and 1990/91 Tempo/Topaz vehicles.
ISSUE: Intermittent fault code "6" (Air Bag Warning on 1990/91 vehicles) or code "32" (High Resistance or Open Circuit on 1992 vehicles) may appear. These codes may be the result of high resistance in the clockspring air bag circuits. Air bag function is not affected.
ACTION: Install an air bag sliding contact assembly (clockspring) service kit. Refer to the instruction sheets included in the kits for installation details. Refer to the parts block for correct parts usage.
Each service kit contains the following items.
^ (1) Contact assembly (clockspring)
^ (1) Instruction sheet for application of air bag sliding contact assembly electrical connector terminal lubricant
^ (1) Lubricant (1/4 oz. Tin Metal Squeeze Tube Nye Nyogel 760G)
^ (1) Instruction sheet regarding Nye Nyogel 760G Lubricant Usage Warning Information
^ (1) Special Instruction sheet (where applicable for certain 1990/91 vehicles) for converting earlier 2 circuit to 5 circuit assembly replacements.
Old 03-27-2006, 01:44 PM
Great info and thanks!!!!
My horn button stopped working about two weeks before the blinking started.
Any additional info on the removal and install would be great too...
Thanks again!
1975 MG Midget
1985 300ZX
Old 03-31-2006, 02:12 AM
Stevo2's Avatar
Thanks again!
I would feel it safer for you to either go down to the local library and pick up a service manual that shows the Air Bag Disarming Procedure and the Clockspring Removal Procedure. Or get a 1 year subscription to an online service manual at www.alldatadiy.com
This is not an area to skimp on safety procedures.
Old 09-03-2006, 12:09 PM
jaringtn jaringtn is offline
I have the same kind of problem with my 92. The air bag light blinks 5 times then pauses and blinks 2 times. Then repeats the entire thing over and over again. Everything else seems to be working but the blinking light is not only annoying but worrisome in terms of safety issues. Please help!
Old 09-03-2006, 11:08 PM
RK4332 RK4332 is offline
Listen to Stevo! Airbags are VERY dangerous to work with if you dont know what your doing. If you decide to do it yourself, make sure your battery cable is disconnected. Airbags are explosive devices. I've done alot of airbag jobs, and i still wont sit in the drivers seat when turning the key on for the first time.
Old 09-06-2006, 12:01 AM
Believe me if the code is something really serious I will be the first to take it to the shop!
