Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 03-16-2006, 07:45 AM
usamarshal usamarshal is offline
Gasket Locations...
I need to replace my lower intake manifold gasket, the distributor mounting gasket, and valve cover gasket. Are all these parts in the same general area? I need some advice on how to go about installing them on the Tahoe. I have a 2000 5.7 liter with four wheel drive. Thanks for the help, Skip
Old 03-16-2006, 09:20 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Gasket Locations...
I asume you have checked it out and are sure the intake gaskets is leaking?
Is there Coolant in oil?
The dist mounting and valve cover gasket are the easy part.
Just pull dist and you will see the gasket on the bottom.
And remove the valve covers and you will see the gasket/seal.
What kind of help do you need like removing the intake or installing the gaskets or putting it back together?
One of the first things is to mark the position of the dist and where the rotor is pointing and do not turn the engine when the dist is out of it.
There is improved gasket sets out there. Dealer or aftermarket.
And make sure you torque everything.
Here is a link to All data DIY repair info online sub that would lead you the the gasket replacement. Very good repair info and it is always there to help you threw it step by step. 24.95$ a year but will pay for itself in one repair.
http://www.alldata.com/products/diy/index.html
Also when you get the gasket changed be sure change that oil and filter a couple of times.
MT
MT
Old 03-16-2006, 01:14 PM
Hey, thanks for the response. I'll make sure to follow these steps and the instructions to the website your provided. Thanks again for the info and I'll let you know how it turns out, Skip
Old 03-16-2006, 01:16 PM
There was no coolant in the oil by the way.
