93 taurus 3.0 no spark
Changed cap and roter, ignition coil, whats next ignition module? any input would be great.. thanks
Re: 93 taurus 3.0 no spark
Are you checking for spark at the plugs, or just guessing you don't have spark since the car doesn't start?
Have you checked for voltage on the primary side of the coil? Is the trigger for the coil good? Did you verify that the crankshaft position sensor is still connected and working? Have you tried to pull trouble codes from the PCM? What is the battery voltage when cranking the engine with the starter? -Rod |
