Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-15-2006, 09:09 PM
Big Dan V Big Dan V is offline
Question 1998 Ram Eng swap 318 for 5.7 Hemi
I have a 1998 Dodge Ram 1500 Pickup (318 cu in)and would like drop in
a Hemi 5.7 or 6.1 eng. What kind of problems should I expect?
Old 03-15-2006, 09:59 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: 1998 Ram Eng swap 318 for 5.7 Hemi
Transmission problems probably. I think Dodge made them out of glass.
My Mopars
Old 03-16-2006, 07:20 AM
tony36 tony36 is offline
Send a message via MSN to tony36
Tranny, computer, maybe sensors in exhaust, motor mounts may be different, radiator may be different. Those are a few things to check out. IT should not be too bad since they put those motors in those trucks, but any swap entales a bit of changes.
Old 03-16-2006, 02:45 PM
neon_rt's Avatar
neon_rt neon_rt is offline
The way I've seen that it could work is to buy the Hemi Crate motor that comes with the FI and ECU as a stand alone device. Otherwise you are going to need a donor truck that already has the Hemi in it and you will have to bring the ECU and supporting wiring to your truck. If the donor truck has built-in security it will not work b/c the BCM and security module will not match up. Because you are removing an engine from a newer truck you would be required by law to conform to the emission standards of the year of the donor truck. If you buy a crate engine, you are only required to meet the emissions of the year of your truck. Oh, BTW the Hemi crate motor is about $8000. If you want that much power, have a supercharger installed on your 318 and call it good. If you don't mind spending $8000 in engine (for the Hemi) and who knows how much more in labor,go for it, or you can spend less and get 350hp from your 318.
Old 03-16-2006, 02:55 PM
imtheoneandonlyD's Avatar
imtheoneandonlyD imtheoneandonlyD is offline
Send a message via AIM to imtheoneandonlyD
Sorry they never had a hemi in the 2nd gens stock.
Pictures of the Truck
Old 03-16-2006, 02:58 PM
Or if money really isnt a concern just drop the hemi in and supercharge that.
Old 03-16-2006, 04:30 PM
BleedDodge's Avatar
Sometimes it makes sense to trade. Dunno what this guy's situation is though. Maybe he wants to pull trailers, maybe he wants to race...
My Mopars
Old 03-16-2006, 04:53 PM
neon_rt's Avatar
If I had a '98 Truck (that was paid for) and $10,000 in my pocket to spend, I would probably trade in the truck for one with a Hemi in it and go from there. I've seen Hemi powered 1500's on used car lots for $15,000. It seems like a better value to trade the '98 and $10000 for one of those.
As far as the 6.1 goes, I doubt if you could ever find one at any price to buy unless you have some real connections somewhere or are willing to buy an SRT-8 just for the motor. I saw in a news article somewhere that Chrysler buys back wrecked SRT-8's so the 6.1 won't be available except through them.
Old 06-30-2010, 04:37 PM
edvorak edvorak is offline
I am planning a 318 to 5.7 Hemi swap in a 98 Dodge Ram 1500 looking for information on swap only. I plan to buy a carb setup from XV motors this kit includes ECU and stand alone wiring harness. I beleive the engine will bolt to the stock trans is this correct ? Also have auto trans with overdrive and lockup torque converter, do I need a module to control trans? I am also not sure if engine mounts are same. any info on swap will be appreciated I have Hemi and am doing swap so do not try to talk me out of it.
