Old 03-15-2006, 07:39 PM
sboater sboater is offline
1995 Pontiac GP issues
I have a friend with a 95 GP 3.1 with a check engine light. I reviewed data and pulled codes and the code is 77 (EGR solenoid #3 malfunction). When looking at the data on the scanner it also shows a bad quad driver 4. Lastly, the a/c seems to be backwards. When the computer shows the a/c request on, the a/c shows disables and when the a/c request is off, the a/c shows enabled. The scanner also cannot reset the codes. I had to disconnect the battery to reset. I am wondering about a bad computer (bad egr still a possibility) as I have seen this on a chevy lumina. Any thoughts?
Old 03-16-2006, 06:00 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 1995 Pontiac GP issues
I would say that the EGR is bad (fairly commn on the 3 solenoid design that car uses, EXPENSIVE too) and the A/C system is low on charge. IT disables the system when A/C is requested because the pressure switch is detecting low system pressure. It shows the system enabled when A/C request is off because it isn't reading the low pressure switch signal, so at that point, it doesn't know the system is low. A bad computer will normally show no codes and will cause intermittent hesitations, stalling and loss of injector pulse among other things.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
