Old 03-15-2006, 06:39 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
91 s-10 problem
my uncles 91 2.8 5speed s-10 is giveing him trouble. He has a new battery and alternator in it and the truck will run not even 5 minenutes and the bettery will die. We can not find out what is causeing this. The motor was rebuilt not to long ago also. If you have Any ideas about what would cause this please let me know. Thanx alot!!
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 03-15-2006, 07:50 PM
Bads Crew's Avatar
Bads Crew Bads Crew is offline
Re: 91 s-10 problem
First, did he install the new alternator and battery because he was having the problem or did it happen after one or both where installed?
Old 03-15-2006, 08:50 PM
97cavalier's Avatar
Re: 91 s-10 problem
the truck has a new motor in it so it has a new alternator and a new battery was installed, i think that there is a wire grounding out some where. I am going to look tommarow and see if i can find any thing.
Old 03-15-2006, 08:59 PM
jackass#1's Avatar
jackass#1 jackass#1 is offline
Send a message via Yahoo to jackass#1
Re: 91 s-10 problem
exactly. have charging systm checked. autozone does it for free. alt. is not charging battery. double check all wiring to alt. red/blk(or red)goes to battery, pnk/blk wire to fuse box(ign/gauge fuse 20amp), brown to chare indecator gauge. check that fuse and make sure conection to battery is clean and tight.
sometimes a rebuilt alt. from parts stores are bad. this could be your case.
Old 03-15-2006, 09:02 PM
97cavalier's Avatar
Re: 91 s-10 problem
i had the alt and battery chacked and they are both good, so it has to be grounding out somewhere.
Old 03-15-2006, 09:05 PM
jackass#1's Avatar
Re: 91 s-10 problem
sounds like a plan. i see youre not new to the forum, so i dont have to tell what to look for while tracing your wiring. good luck. let us now how it turns out.
Old 03-15-2006, 09:08 PM
97cavalier's Avatar
Re: 91 s-10 problem
yep, i will let you know as soon as i find out.
Old 03-21-2006, 12:57 PM
Paperboy1996 Paperboy1996 is offline
Re: 91 s-10 problem
Just a little somthing to think about - about 10 years ago I had the same problem, took the alternator down had it tested(twice) they said it was good both times, check all the wiring still no luck, finally I changed the alternator anyway and that is what it was, aparently the alternator it self shorted out when it was tested it tested ok but on the vehicle it would loose more power than it could provide.
Good Luck !!
Old 03-21-2006, 09:00 PM
blackblaz's Avatar
blackblaz blackblaz is offline
Re: 91 s-10 problem
I was speeding up past the fuckin' Convent of nuns off Franklin last night where they installed speedbumps and knocked my leadwire out of the ignition coil! I just totally died and wouldn't restart till I popped the hood, you might wanna check the wires to the coil or from the coil.
Throw a 350 innit!
Old 03-21-2006, 10:54 PM
97cavalier's Avatar
Re: 91 s-10 problem
ok, here is the update, i looked at it, and some 16year old kid had it befor him and had a system in it and the stero system in it. So first off some of thoes wires were grounding off the battery. And i looked at the battery positive cable and where it screw to the battery the threads were striped so it was not getting a good conecion. And then who ever installed the new motor, screwed up alot of wireing under the dash by the fuse box. Half the fuses were not even there, and some wires were dangeling. So my uncle just talked to the guy who he bought it from and he gave him his money back. Thanx alot for all your guys help!!!
