Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 03-15-2006, 05:34 PM
Witty690 Witty690 is offline
Gas Leak
I have a 93 cougar xr7. Recently, my car has been smelling like gas, and I've been gettibg crappy gas mileage. I think I nay have a gas leak. How can I find out what it is, where it is, how to fix it, etc. Thx in advance
Old 03-16-2006, 01:08 AM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Re: Gas Leak
Injector seals leaking, fuel filter leak, gas tank leak on top or bottom, follow the fuel line/s from the tank forward and look for stains near the fuel lines or on the frame.
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
Old 03-16-2006, 11:07 AM
KaeJR KaeJR is offline
Re: Gas Leak
what you are experiencing has nothing to do with the gas tank. I had the same problem about 3 months ago. What has happened is that your gas line has sprung a small pin hole that has been caused by your rear passenger side fender rubbing against the line. There was actually a recall done on this up until the middle of last year. You will have to get a new gas line installed. If you go to your local salvage yard then you will save a lot of money. I didn't know any better and paid 170.00 for my repair.
Signs of this include: gas smell in car, your rear wheel may slip from time to time when you pull off (mostly at stop lights.)
The best way to find out for sure is to put your car on cement or blacktop and let it run. the leak will run down the line and drip right before it meets the tank.
