Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 08-11-2001, 09:47 AM
Soleman20 Soleman20 is offline
Send a message via AIM to Soleman20
JWT POP vs. STILLEN POP
I have a 1994 G20t. There is some sort of air sensor imbedded in the side of the stock air box. I want to get a JWT POP charger but I have heard that it has no spot to put the sensor. STILLEN on the other hand, lets you choose between 2 (w/sensor or without sensor).
STILLEN INTAKE +HI FLOW INTAKE, 94-6, G-20 W/SENSOR 94-96
STILLEN INTAKE +HI FLOW INTAKE, 91-4 SER/NX/G-20 91-94
Even though the JWT is a much better price, I don't want to get it and have no place to put the air sensor. Can anyone help??
Old 08-11-2001, 09:53 PM
P10DET's Avatar
P10DET P10DET is offline
Re: JWT POP vs. STILLEN POP
All you have to do is drill 3 holes in the end plate of the filter. Or just tie-wrap the sensor to the outside of the filter. That is what JWT recommends. It only needs to be near the filter.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 08-12-2001, 10:24 AM
NismoPC's Avatar
NismoPC NismoPC is offline
My $tillen intake was originally purchased in '94 for my '91 NX2000 w/o sensor. I sold the NX and put the intake on my '96 G20 w/sensor. I purchased a new K&N filter and wanted to attach the sensor to it. Here is what I did:
1. I used the brass plate from the sensor for a template to drill the holes on the chrome end cap of the K&N filter. For aesthetic purposes I mounted the sensor below the K&N logo (see pics)
2. I used a small knife and needle nose pliers and pulled off the rubber from inside the filter so that I could use the original sensor bracket and screws. This makes for a flush fit.
3. Installed the K&N on the $tillen intake and Voila'
Brandon
'96 G20 - modified
Old 08-12-2001, 10:39 AM
aluke000 aluke000 is offline
My filter has more filter surface at the end and no metal endcap. Regarding tie-wrapping the sensor to the filter surface, aren't you going to get filter oil on the sensor and get false readings as a result?
Old 08-13-2001, 06:44 AM
P10DET's Avatar
That makes no difference. It's a marketing ploy.
Not unless you over oiled the filter. And, you don't have to have the sensor touching the filter. It just needs to be near it.
George Roffe
Houston, Texas USA
00 328i
Old 08-13-2001, 09:00 AM
RCer's Avatar
RCer RCer is offline
George, what happens if you over oil the filter? Do the engine suck that oil? Does it cause any damage?
Americo
2000 Primera.
Old 08-13-2001, 11:06 AM
Since I couldn't mount the sensor in the end (due to not having a solid endcap to mount it to), I ended up mounting it on the opposite surface on the flat base next to the clamp. It had to remove a couple of layers of gasket off of the sensor but it fit nicely. This is actually very close to the factory mounting loaction so I was able to use the original bracket too for a more finished look.
Old 08-13-2001, 01:21 PM
MoReace MoReace is offline
Send a message via AIM to MoReace
I couldn't see myself paying all that money for a pop charger so my friends was nice enough to custom make one for me. He drilled a hole for the sensor behind the filter and it works great.
