Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-15-2006, 02:45 PM
shearphysics shearphysics is offline
cams
ok i just my 1g running after ecu trouble,when i start the car it idles at like 2,000rpms for about 5to10 min then it slowly drops to 800 rpms.when i drive it the cams get loud at about 2,500 rpms does anyone know what this could be im not sure if its the cams but thats what it sounds like.to me it sounds like a performance cams.thanks im new to the dsm world .
Old 03-15-2006, 03:05 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
Re: cams
SEARCH! you got a big problem sounds like... car in sig with mods.. thank you come again
Old 03-15-2006, 05:14 PM
Re: cams
ther are no mods the cams only get loud between 2,000 to 3,000rpms then they get quit
Old 03-15-2006, 10:05 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: cams
If it's idling bad it could have a boost leak (if it's turbo, put your car in your sig, year, model, etc) Could be a problem with the turbo (if you have one)
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 03-16-2006, 02:32 PM
Re: cams
the car has no turbo so that cant be the problem.the header is cracked do u think this could cause the problem.but it only gets loud at 2,000 to 3,000.it only idle high when i first start the car then it goes back to normal.thanks
Old 03-16-2006, 09:58 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: cams
Every DSM I have ever seen idles at 2k right at start up and falls to 750-800 after that, you are fine there.
How you do you know the cams are getting loud? Are they clunking around? If they were, your car wouldnt run for more than a few seconds before it either shuts down or blows up.
You need to tell us what the sound is. If your manifold has a crack in it, why the hell would you think its anything else? Fix your manifold and see if it helps any.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 03-17-2006, 01:45 PM
Re: cams
ok does anyone know where to get a 2g manifold for cheap
Old 03-17-2006, 01:54 PM
Re: cams
no the cams arent clunking around they make a noise like if u ran a motor with no oil.but the car runs fine theres no lack of power or anything.and before u ask yes there is oil in my motor im not that stupid.the thing that doesnt make sense is its only betweem 2k to 3k it make the noise, after 3k it make no sound.thanks
Old 03-17-2006, 11:39 PM
Thor06's Avatar
Jizzed In My Pants
Re: cams
Lifter tick?
