Old 03-15-2006, 01:34 PM
Cntrysthbst Cntrysthbst is offline
Send a message via Yahoo to Cntrysthbst
Sub-frame alignment help!!!
It's a 1992 Buick Park Avenue. Replaced the sub bushings and some engine mounts, anti-sway too. Car pulls real hard now in take off, it is aligned but specs are different than before. The front right tire is more forward than the other now. I need to set the frame straight, is there any alignment marks or holes I can look for when doing this? Any help in how to align this would be great!!! Thanks!
Old 03-15-2006, 04:48 PM
maxwedge maxwedge is offline
A990 racer
Re: Sub-frame alignment help!!!
Get the wheel base left to right as close as possible, with the wheels dead straight ahead, measure the lt wheel base to the rt wheel base, get them with a 1/4 inch or less, when aligning the car this shows as setback, should be .2 degrees or less. You will need to realign the car when you are finished with this, look at the setback on the printout then.
Old 03-15-2006, 08:38 PM
Will do - thanks!
