460/C6 into 89 tbird
Im planning to drop a 460 into my 89 tbird. Has anyone done this? Trying to gather as much information about this before I start. Also, wondering if the rear end will hold up to the new found power.
Re: 460/C6 into 89 tbird
if there are smog laws, they will be on you
depends on which rear you have... and it seems a lil big to stuff into that bay to me...but it might be able to be done...
![]() My new RHD project! Solid Crew (Circa 2002) |
I knew a guy who did this but his was for a drag car not a street car.
You better have lots of weight in the rear to offset the enormous weight on the front as well as heavy duty front suspension. TerminalVelocity brought up a very good point about the rear, I do not think the stock rear in the 89 will withstand the torque from the 460. I have a 72 T-bird with the 460 and the 8.8 rear is has holds up well but you may want to upgrade to a heavy duty racing axle and differential. If you use the stock axle you will destroy it in a very short time. All other problems aside this is one you will need to spend some serious $$ on. My friend used an aluminum racing rear axle and it set him back around $20k but he is a serious racer/dragster. You may want to contact a good speed shop or racing shop and get some options. I will warn you this is going to be very $$$$$$. If you get it done please post some pics I am sure we would all love to see it. Good luck with it Mark
If you can't get there in a Thunderbird, the trip ain't worth taking! |
460 In An SC.
The above link is a thread discussing the swap. Mike Tymensky's drag car That motor actually is a 514 I think, but it is same block and heads as 460. |
