Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 03-15-2006, 11:03 AM
ramos ramos is offline
96 altima rpm/idle problem
i have a 96 altima with 160,000 miles the car will turn off when its on idle & press the gas pedal to about 6000rpm afeter it kills itself wont start, have to wait 30 to 45 min & will start again. i have changed recently the distributor, distributor cap, rotor, crankshaft sensor and egr valve about six months ago. i noticed also that if i drive car will get about to 50mph & will die on me on the road & wont start either, also noticed that after it dies if i turn key to on position 3 to 4 times the car will start ?? please advise with any help.
Old 05-06-2006, 08:13 PM
x1gary's Avatar
x1gary x1gary is offline
Send a message via AIM to x1gary Send a message via MSN to x1gary Send a message via Yahoo to x1gary
Re: 96 altima rpm/idle problem
Crank Case Sensor ... Should be 2 or 3 of em ...
-G-
Altima G
Old 05-06-2006, 08:42 PM
FixUrNissan's Avatar
FixUrNissan FixUrNissan is offline
I wonder.. It almost sounds like it could be an ignition switch .. When you run into the situation were you cant start it.. Try to turn the ignition switch very slowly , If it starts as you cycle the key and dies as you finish the cycle , then it would be a bad switch in the ignition cylinder and would need to be replaced. Other than that, the only other thing i could think of that would make a car die when driving is the distributor. Even though you changed it, I have seen after market distributor go with in a month or so . GL
Old 05-09-2006, 10:10 AM
i recently bought a nissan brand distribuitor, cap & roter so i will instalit this week end hopefully that is the problem thanks for your advise.
