Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 03-15-2006, 10:07 AM
usamarshal usamarshal is offline
Rear Differential Fluid Change...
When changing the rear differential fluid do I need to take the rear plate off to drain the fluid or is there a release valve or bolt somewhere? I found where I insert the fluid, but not the drain bolt. I have a 2000 5.7 liter with old body style with four wheel drive. Please help!!! Thanks, Skip
Old 03-15-2006, 10:08 AM
Re: Rear Differential Fluid Change...
Oh yeah, that goes for the front diff too.
Old 03-15-2006, 05:49 PM
2000CAYukon 2000CAYukon is offline
Rear diff, you will have to take off the cover plate to drain the fluid. I like to put a new gasket in when I change the fluid.
Front diff should have a drain plug so you will not have to remove the cover to drain.
//2000CAYukon
Old 03-15-2006, 07:52 PM
Good idea, I'll make sure to do that. Thanks for the info, Skip
Old 03-16-2006, 12:38 PM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
If you want a good gear oil, use royal purple, may cost a little more but well worth it.
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
Old 03-16-2006, 01:10 PM
Sounds like a plan, I'll check out the local auto parts stores and see if they have it in stock. Thanks, Skip
Old 03-16-2006, 05:14 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
And if postive track rear end use the correct fluid or the additive for it.
MT
MT
