Old 03-14-2006, 11:05 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Rearview mirrors.
Not the ones out on the sides of the car, but hanging from the windshield, inside. How do you folks attach them? I've yet to find a decent way that doesn't leave a mess, that doesn't leave the mirror crooked, that doesn't let the mirror drop off later. Augh!
Old 03-14-2006, 11:33 PM
freakmech's Avatar
freakmech freakmech is offline
Send a message via AIM to freakmech
Re: Rearview mirrors.
The way i do it is this. i put a small bit of blue tack on the end of the mirror that needs to be attached. but i poke the end through just enough to apply BSI Gold CA 30-second type (non fogging) to the tip. I then carefully line up the tip to were it is to be located and stick it on, holding it in place with the bluetack. 30-second type allows me to straighten it out so it isnt crooked. then i let it dry for a few hours and carefully remove the bluetack. does this make sense to you?
Friends dont let friends buy die-casts...
"If it can't run 24hrs., it aint sh!t...." -me
Old 03-14-2006, 11:51 PM
Totally, and that's brilliant!
Old 03-15-2006, 08:03 AM
toyota00 toyota00 is offline
That sounds like a real good way. I have trouble with those little dang mirrors too.
Old 03-15-2006, 02:29 PM
winstona's Avatar
winstona winstona is offline
Brilliant method! For me I just use regular model glue and hope for the best... I tried double sided tape cut into very small size. But the tape is not totally transparent. It works for some models but not all . When the end of the mirror piece is not attached to the front windshield, the double sided tape will not be visible.
Winston
Old 03-15-2006, 08:12 PM
MidMazar's Avatar
MidMazar MidMazar is offline
I find that some of them have an imprint on the windshield where they go, so in that case i paint that tiny section black (on the inside), then once dry i use a tooth pick with some super glue, dab a tiny bit on the mirror and then tweezers finish it off. That does the trick for me. No more seeing that glue, all you see is a black dot where the mirror is attached. Hopefully i clarified it well enough to understand.
In Progress
The Following User Says Thank You to MidMazar For This Useful Post:
circuitR (04-14-2017)
Old 03-15-2006, 11:22 PM
blubaja's Avatar
blubaja blubaja is offline
Tamiya clear. Dip the end in it. A side note...um...on the 1:1 windsheilds we do...sometimes the mirrors do go on crooked..but shhhh!
Old 03-16-2006, 07:49 PM
Jay! Jay! is offline
Horizontally Opposed
Originally Posted by The Gumball Rally (1976)
Franco: And now my friend, the first-a rule of Italian driving.
[Franco rips off his rear-view mirror and throws it out of the car]
Franco: What's-a behind me is not important.
Drop of white glue. I have more trouble keeping my fingerprints off the foil face...
Hierarchy of Subaru:
(Click to see mine!)
Old 03-16-2006, 08:10 PM
Who the F are you?!
The Following User Says Thank You to willimo For This Useful Post:
tonioseven (04-30-2017)
Old 03-17-2006, 05:07 AM
wouter1981 wouter1981 is offline
well, I use 2compound gleu. I mix a tiny bit.. let it dry a few minutes and when it becomes thick i put a tiny bit on the mirror and press it on the glass. Because the glue has dryed a bit, it sticks instantly and when its cured, it's barely visible and much stronger than whit glue.
Old 03-17-2006, 04:02 PM
tpliquid tpliquid is offline
Send a message via AIM to tpliquid
I too use tamiya super thin glue. small bit of it works great dries clear
friends let friends drive benzes
Old 03-17-2006, 06:35 PM
D_LaMz's Avatar
D_LaMz D_LaMz is offline
white glue
Old 03-17-2006, 07:21 PM
blubaja's Avatar
Originally Posted by willimo
Who the F are you?!
Hehehe..yea..since when does Jay post on these boards?
Does this mean you are going to do models agian Jay? Jay? JAY!!!!??!!!
Old 03-18-2006, 10:49 AM
Lambo003's Avatar
Lambo003 Lambo003 is offline
I use Delta CeramCoat Gloss Varnish. . .
Dries pretty fast and is stronger than regular hobby clears and flexible. . .
1000's of other uses too. . . Applying PE to just about anything that needs a good strong clear coat. . . I won't build without it. . .
Chuck
Old 03-28-2017, 08:46 AM
Exotics_Builder Exotics_Builder is offline
Hypoid cement (watch crystal glue) applied with a pointed toothpick. Allows for positioning but tries fairly quick.
