Old 03-14-2006, 10:38 PM
dampontiac dampontiac is offline
96 lumina 3.1 help
So i got this 96 lumina for free
then found out it didn't have the correct motor
what was reinstalled in the car was a 3.1 from a 95 pontiac grand am, is there a way to make everything work on the motor? it doesn't run and it is throwing about seven(7) check engine codes
if anyone has come across this issue i would be in great graditude of you! if you can give me any help.
thank you in advance!!
Old 03-15-2006, 05:04 AM
maxwedge maxwedge is offline
A990 racer
Re: 96 lumina 3.1 help
These engines have different pcms to start with, harnesses may be different also.
Old 03-15-2006, 10:44 AM
Would i be apble to get a pcm for a 95 grand am and put it in the lumina??
Old 03-16-2006, 12:22 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
If the Grand Am motor is a roller rocker arm engine, other than a sensor or two, it should work. If the engine is a ball and pivot style rocker engine, they are not interchangeable, and you will spend more money trying to make it work than the car is worth. A Grand Am PCM will not work in your Lumina.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 03-16-2006, 12:40 PM
I am not sure what the differences are between a roller rocker arm and a ball and pivot style. is there a way i can tell by looking at the thing?
and do you know what sensors i could change if i do have the correct one?
Old 03-16-2006, 02:01 PM
richtazz's Avatar
Externally, you can't tell. You'll have to pull a valve cover and look at the rocker arm. If it has roller bearings in the center where it pivots, it's a roller type and if not, it's a ball and pivot type. Sensors that may need to be changed are the CTS, oil pressure switch and TPS.
