Old 03-14-2006, 10:06 PM
MMonnier2302 MMonnier2302 is offline
Lt1 swap
i own a 95 Z28
my question is the engine is shot, its spun a rod needs a new crank blah blah blah.........price speadshop says 2500 for a rebuild
ive found a used 93 Lt1 with 45000 miles on her for well under 2000, the tricking thing is that its out of a vette, but still has the wiring harness.
can it be swapped?
there both six-speeds if that matters
i love dem bats!!
1995 Camaro Z-28
2000 Dodge Ram 4x4 Sport 5.9
Old 03-14-2006, 10:19 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: Lt1 swap
since you have your motor, have your lt1 built to a 383 stroker!!
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
FTheMan FTheMan is offline
Re: Lt1 swap
Yeah...
Old 03-14-2006, 10:24 PM
Re: Lt1 swap
sounds good but money is an issue, and i would like to drive the car soon.
i could have the old block rebuild how i want it, but thats gonna take some time hence the whole money thing
but seriously is this within reason?
anyone have advice for computer/wiring?
i love dem bats!!
1995 Camaro Z-28
Old 03-14-2006, 10:26 PM
Re: Lt1 swap
It came with the wires but no computer? I believe you have to replace it. I think..
Old 03-14-2006, 10:52 PM
97cavalier's Avatar
Re: Lt1 swap
your 95 has vented optic spark but i don't know if that will change any wiring because the 93 has non vented. Other wise it should bolt right in.
Old 03-16-2006, 12:33 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Lt1 swap
It will fit but you need to change a few things on the block. Like the motor mounts are obviously different. To get the Driveside mount in you need to remove the extra knock sensor. The coolant temp sensor is on the wrong side of the engine so you need to remove that plug from the head and switch it for the coolant temp sensor. The wiring harness needs to be swapped for your current engine. The accessory bracket needs to be switch from your current engine. The intake manifold and fuel rail need to be switched and you might need a little fab work on the starter hook up. Also the oil pump strainer needs to be changed to a f-body one and the oil pan needs to be swapped for your old one (make sure you clean it out good cause there will be metal shaving in the old pan and you don't want that running in the vette engine's oil stream.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 03-16-2006, 12:35 PM
FormulaLT1's Avatar
Fight the powwa!!!
Re: Lt1 swap
Also, the exhaust manifold needs to be switched.
