| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
I know we have discussed this about which head gasket i should get, well i got it the 4 layer metal head gasket. I just want to make sure thats all on this final say before i install the gasket!! Should i or should i not!! put anything on the gasket when i install it? Being metal it will not leak fluids not having anyhting on it? Thanx Guys
Here is a pic of the gasket Mitsubishi Part# MD349347
Current Cars 2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod. 2003 Grand AM GT - official beater car for the winter lol ---------------------------------------------------- 95 TSI AWD [email protected] (T-25) Now fully Modded engine with 3,560 miles on it.SOLD |
Re: Final say on my Head gasket
I have a thought, I'm probably wrong but will the metal make bigger stroke? I don't know how thick it is, that's probably what I'm asking?
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff. http://www.ratemydsm.com/member/ez1286/?member=ez1286
I can't see the pic very well, but it looks like the water passages have a sealing ring around them already. So no do not put anything on the gasket.
The thicker gasket will lower compression slightly, but since your head is shaved so much I wouldn't worry. It probably equals out.
![]() 96 GST 5 spd.......(R.I.P.) smashed by a fallen tree 2001 Camaro SS 6 speed goodness! |
I thought that I was going out on a limb by saying that, I wasn't sure that's why I asked.
The stock gasket is pretty thick, I want to say .054 compressed or something along those lines. The MLS gasket isn't much thicker IIRC. It does have rubber like sealing rings at all the important places, I always install them dry. And just for reference, the EVO uses a mitsu MLS gasket stock, so they are perfectly reliable. I've even reused them successfully. I wrote up a bunch of info about how to properly install the head studs (Which I hope you are doing at the same time, if you haven't already), check and see if it's on my site before you do the install. It would have saved me a couple HGs back in my younger days
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
them black rings you see do not feal like rubber!!! it all feels like metal, when i get off work i will take a closer look at it.
It's a coating. Somewhat like the green shit on the TB and intake manifold gaskets.
I know you know what your talking about but this does not feel like a coating, I tried to scratch it with my finger nail but i couldnt so if it is a coating its a hard damn coating. Is it the same mls HG you use? Part# MD349347 Here is a closer pic
It may not be so hard under high pressure and high temperature. It's definitely not there for asthetic reasons.
I have never sprayed anything on it, and I've run them to 30 psi and ~55 lbs/min. With normal head and block finishies. With regular metal gaskets like Cometics, you need a special finish (extra smooth, finish RA of 30 or less IIRC) to get a good seal, and most poeple use a copper spray or similar on them, and they don't have the black BS you see on the Mitsu piece.
Ok cool thanx man, Thats all i needed to know
Wait, so with a Cometic gasket you need to use copper spray and machine it to that special smoothness, but you dont need the spray or special finish on the oem metal hg? Can the oem one take as much boost? Where did you get it and for how much?
. I got it in 3 days standard shipping, off of a DSM website!!!Yes with cometic you need a special surface.
Cometics are 95-105 from SBR depending on whether you want the normal one or the high boost one. 35 PSI is the very most I would run, so that would be fine. Your gasket doesnt need the extra machining though? Would you happen to remember what brand it is?
