| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
I did some searching but the only thing i came up with is torque sequence for the head. What about putting the studs in the block? Do i just hand tighten them or is there a torque for them? And also i came across that people using the arp studs are torqueing them down more than stock, is this a good thing to do? Most of them are torqueing the final torque at 90 Foot Pounds, what should i do using the 4 layer metal head gasket?
Current Cars 2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod. 2003 Grand AM GT - official beater car for the winter lol ---------------------------------------------------- 95 TSI AWD [email protected] (T-25) Now fully Modded engine with 3,560 miles on it.SOLD |
Re: About the arp head studs!!
I think you should do what arp recommends use the part number at their site http://www.arp-bolts.com/
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff. http://www.ratemydsm.com/member/ez1286/?member=ez1286
I have a bunch of info on this on my site:
http://www.posracing.net/ARPstuds.html I used to go a little over the ARP numbers, but lately I've been following thier recomendation after they said that since aluminum expands faster than the cast block you should actually use a litttle LESS torque... So I just go for the recomended value. Just remember the studs we use are 190k psi, and 6 bolt is 12mm and 7 bolt is 11mm, so you get the right tq value. And use the ARP lube! As suggested in that link...
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
So by what your site says, just put them in the block hand tight? Well that is easy enough.
Yes, hand tight, to avoid distortion when the nuts are torqued.
ok man thanx alot for your info, i will be completing my engine this weekend. Then my next step is to take my tranny out and clean it up. I will take pics of my progress to all updated!!!
