Old 03-14-2006, 02:55 PM
shortie66112 shortie66112 is offline
93 Lumina please help
I have a 93 Lumina that will not stay running it will run for about 10-15 mins then dies and is hard to start back up. Has new fuel pump was having problem with backfiring through the breather used fuel injector cleaner and that went away. It has 136691 miles
Old 03-14-2006, 03:03 PM
us5camp us5camp is offline
Re: 93 Lumina please help
I had the same problem.
Check your plug wires and/or coil for arcing (at night).
Our starting problems and backfire were 100% due to the arcing caused by bad plug wires.
Old 03-15-2006, 10:11 AM
comptech_69 comptech_69 is offline
Send a message via AIM to comptech_69 Send a message via Yahoo to comptech_69
This is a very common problem with these cars when they get high milage on them. Like you said you used fuel injector cleaner and it went away for a bit... Your furl injectors need professional servicing or to be replaced because they are clogged. It only does it after a few minuteds becuase when the car warms up the ECM changes the air/fuel mixture and this is where the injectors cant keep up
www.theimportkiller.com
Old 03-15-2006, 12:50 PM
3.1L 200+hp's Avatar
3.1L 200+hp 3.1L 200+hp is offline
yes more than likly the plugs are getting to much gas and is not able to burn it all
Old 03-16-2006, 11:55 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Try a simple tune-up (including new fuel filter) if it's been a while since you have. Never replace expensive parts before doing regular maintenance stuff.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 03-16-2006, 01:06 PM
checking to see if ur car is getting to much fuel is free pull out a pplug and see what it looks like if its black and wet then to much gas
