Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-14-2006, 11:02 AM
Honda_Sir_1 Honda_Sir_1 is offline
Exclamation 1993 honda civic shuts off when started!!!
Hey all, thanks for taking the time to read my thread.. heres the deal i have a 1993 honda civic hatchback its my baby and sometimes when i go to start it it will sort-of hesitate to start and if it does it will idle kinda low then shut off, like i will go to start it and it will start most of the time then kinda run low then hestitate to shut off ,i know ,i have a messed up clutch cylinder and i know it holds the brake fluid AND IT LEAKS VERY VERY VERY LITTLE SO MAYBE THAT COULD BE IT (ITS NOT THE MASTER BRAKE CYLINDER HAD THAT REPLACED) ITS THE CLUTCH CYLINDER. any informayion on this problem would surely be appreciated ty!
Old 03-14-2006, 11:06 AM
Re: 1993 honda civic shuts off when started!!!
also,,,,,,,,,,,,,, i changed the park plug wires and the spark plugs so what is wrong ....!!!!!!!
Old 03-17-2006, 12:17 AM
ATMDC's Avatar
ATMDC ATMDC is offline
try checking the timing
Old 03-17-2006, 01:24 PM
hxgaser hxgaser is offline
It might just need a tune up. Check cap and rotor. Check spark plugs and etc. Also fuel filter might need replacement. Could be clogged injectors. If none of the above is wrong, then check vacuum related stuff. Start from the throttle body to intake. Spray WD40 or any aerosol around intake while the car is running. If the idle changes significantly you can isolate where the leak is. You can also check around the head gasket and all vacuum hose runs.
