1995 dodge caravan Hesitates when idle
I have a 1995 dodge caravan, first the heater started leaking water, then all of a sudden it won’t start brought it to get fix, they said it was a ignition switch that was on the transmission, when we got home it won’t idle right and it acts like it it’s going to stall, some times it does, if you on hook the battery for 30 minutes or longer it will run fine for a little while, then it will start acting up again. It almost feels like it’s not getting any gas, when my mechanic hook it up to the machine it said the coil was bad replace that and still acts up. does any one have any idea? Please help… my mechanic has no idea what it might be.
Email: [email protected] |
Re: 1995 dodge caravan Hesitates when idle
Are there any codes from the diagnostic check?
What motor and transmission is this? sounds more like a TPS/MAP/TEMP sensor or fuel delivery problem, or of course a loose or disconnected wire... Give us a little more info. Tom
If I knew what I did to break it, I would've known not to do what I did.www.classicwinnebago.com |
My mechanic said when he put it on the machine it said it was a coil, we replace that ran fine for a little while then it start again, The motor is a 3.3 L, Transmission I don’t know for sure. Before this started happening out of the blue it would not start after I got gas, so we replace the crank sensor, ever since then we have been having this problem. I already check all the wires, but could it be a wire harness?
Just for the heck of it, since you said you replaced the crank sensor, go back and put a thin washer between the sensor and the block so that it sticks out a little more. My brother and I had a similar problem with and Intrepid with a 3.3 and there is supposed to a spacer that should have been in the box with the crank sensor. After I put that shim in there, we have not had any problems with it, apparenty the sensor was too close to the flywheel and that was causing it to give erratic readings.
I did a code check when you turn the key on and off a feww times. the light blink 12 then 55. does any one know what that means?
it just did a code check again and it said 31. i know it is Bad evaporator purge solenoid circuit or driver, does anyone know how to fix it?
I have a 1995 dodge grand caravan 3.3L motor with 177.776 miles on it, it won't start and if it does it will stall and sputter,I change the map sensor, egr, o2 sensor,check the fuel filter, check all the vacum lines, check the exhaust system and it still acts up. does anyone know if there is any fusible links any where??
or does any one knows if it might be any of these:Idle Control Valve, fly wheel sensor knock sensor Hall Effect sensor Idle Control Valve, email me at: [email protected]
