Go Back   Automotive Forums Car Chat > Dodge > Daytona
Old 03-14-2006, 11:02 AM
88pacifica 88pacifica is offline
Cool turbos???
hello I have an 88' pacifica and it has started to burn anti-freeze out the exhaust pipe as well as inside the engine compartment from behind the motor. All the wonderful signs of a blown head gasket but now water in the oil. i think it is my turbo personally but never torn into it. just curious about some options to replacing the turbo...
thnx
Old 03-25-2006, 10:43 PM
convdart convdart is offline
Send a message via AIM to convdart
Re: turbos???
I think you can by them brand new. There are also rebuild kits for them. I put a new turbo in my '87 Daytona.
Old 04-03-2006, 11:48 AM
AWP9521 AWP9521 is offline
Re: turbos???
A Turbo when it goes will normally blow Oil Smoke out of the exhaust and some will also be seen in the intake side, If water is escaping out of the turvo it will usually be a line or the center housing has cracked but usually don't make it to the exhause pipe. That and the Turbo would be very noisy because the bearings are shot and the turbine blades will be hitting the housing.
Do a compression check of the engine, I'm banking it to be the head gasket went bad, that is a more commonly known failure on the Chrysler Turbo 4's.
Originally Posted by AWP9521 - 02/16/2005
Sure sex is a thrill too, but your modified car will never tell you
"Sorry honey, I just don't feel like it tonight" it will always be in
the garage silently waiting for you to hop in so it can thrill you
some more, that is unless you break it. At least they're easier
to repair and get the thrill back than a pissed off girlfriend.
