Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 03-14-2006, 09:26 AM
goosecoid goosecoid is offline
Wheel bearings
Has anyone had any problems with Explorers and wheel bearings? I have a 2002 with a little over 50K miles on it. It's currently in the shop for its second wheel bearing replacement (rear rt wheel). The first bearing replacement (front rt wheel) was literally two months ago. Is it normal for a car to wear through wheel bearings so quickly? Am I doing something wrong?
This is my third vehicle and I've driven other cars to nearly 200K miles and never had to replace the wheel bearings...... I think I may have bought a lemon!
Old 03-17-2006, 03:20 PM
mtmaurer8ooo mtmaurer8ooo is offline
Re: Wheel bearings
The wheel bearings are a problem w/ the newer independent rear axle Explorers/Mountaineers. We have 4 rear bearings on our shelves at all times and we stock the front hubs also...if that gives you a clue. As far as why your particular Expo is shredding bearings so quickly...I couldn't say. My guess is that it's not something you're doing, but rather that the bearings aren't rated high enough for the weight of the truck, which means...someone screwed up(Ford Engineers???) If you were replacing the same bearing I would be suprized but at least its using up spinners on different wheels. BTW. Are you using a Ford bearing, or an aftermarket brand...that may make some difference. The Ford front hub is an updated part, so it's probably better than the factory part...the rear unfortunately is not updated. Good Luck. I hope this helps. MM.
"Listen to me Hillary. I'm not the first guy who fell in love with a woman that he met at a restaurant who turned out to be the daughter of a kidnapped scientist only to lose her to her childhood lover who she last saw on a deserted island who then turned out fifteen years later to be the leader of the French underground."
