Losing clutch fluid
I noticed a while back that my 94 2.3L 5sp was getting a little cranky when I would shift. I checked the fluid and it was a little low and the rubber bladder thing was fully expanded. I popped it back into shape and refilled the reservoir, then pumped the clutch a few times and it started acting okay again. A few weeks later the problem returned and I sort of ignored it.
This problem gradually worsened until I one day I started having to match the engine speed just right to get it to shift at all. I checked for fluid leaks in the lines and at the master cylinder but saw none. I read a few posts about similar problems and decided to bleed the clutch hydraulic system. This wasn't too much trouble (the bleeder nut is 5/64ths if anyone wants to know) but the fluid was dark and oily looking on the slave-side. I could find no sign of a leak near the slave cylinder (but I couldn't see everything through that tiny inspection hole, either), so I finished bleeding the line. After that the truck shifted like new.
Now it's been almost two weeks and the shifting problem is starting again. I checked the fluid level this morning. It was about an ounce low and the bladder was expanded again. Still no sign of a leak but when I looked inside the reservoir I noticed the fluid had what looked like dark oil drops in it. I filled the reservoir and the shifting returned almost to normal after I pumped the clutch pedal several times.
Does this sound like a bad master/slave cylinder or what? Any suggestions would be helpful!
Also, is there any way to tell which cylinder (master or slave) is bad?
