Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 03-14-2006, 07:17 AM
dadof4s dadof4s is offline
Send a message via AIM to dadof4s Send a message via Yahoo to dadof4s
'92 MGM hard start when warmed up
1992 MGM, step-daughters car, died on her a couple of nights ago. Someone brought her home and I went to get the car. It started but took some time doing it. I got it home and replaced the plugs. It started a lot easier so I drove it a few miles. When I got back home, I killed it and started it back up. To start it I had to push the accelator all the way to the floor and hold it there and crank a lot longer then I like to. It started but of course was flooded. Do you think this might be a coil pack? How do I check the coil pack to see if it is working properly?
Thanks for any help.
Old 03-14-2006, 02:17 PM
Hollowcreek Hollowcreek is offline
Re: '92 MGM hard start when warmed up
Its not the coil pack. It happened to me a few years back on my '00. The dealer replaced the Throttle Positioning Sensor and it was fine. Had I known it was that easy I would have done it myself. Ended up running about $200 at the dealer.
Old 03-15-2006, 04:30 AM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Could also be a bad Idle Air Control Valve on the throttle body.
Description and Operation
PURPOSE
The Idle Air Control (IAC) valve controls engine idle speeds, both cold and warm engine conditions.
OPERATION
The valve allows a monitored amount of air to pass around the throttle plate to control the following:
Fast idle for cold engine start-up
Idle dashpot
Start-up without pumping the accelerator pedal
Idle speed increase for an overheat condition
Engine idle load correction
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
Old 03-15-2006, 06:38 AM
Thanks for the replies. Now how do I determine which one it is or do I just replace both of them?
Old 03-20-2006, 02:08 AM
Stevo2's Avatar
I personally would try the valve first. Make sure the port under the valve where it mounts is free of crud.
Old 03-20-2006, 06:56 AM
Thanks, Stevo. I will try this in a few days when I can get my stepdaughter to leave the car here.
