Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 03-14-2006, 05:53 AM
butchsterling butchsterling is offline
changing fluid in torque converter
I am going to change tranny fluid in 94 Transport. should I drain torque converter? If so how do you refill converter?
Old 03-14-2006, 07:23 AM
LMP's Avatar
LMP LMP is offline
Re: changing fluid in torque converter
I think the real problem is how do you DRAIN the torque converter..unless informed of the contrary, there seems to be no drain plug on the converter....so with the help of gravity, a little less than half the torque converter contents will be left unchanged.
In as much as filling is concerned, it will fill by itself as soon as the engine is started and transmission engaged. ...you will have to top up the transmission fluid level in several steps following that.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 03-16-2006, 07:17 PM
cdru's Avatar
cdru cdru is offline
The normal way to do it with the transmission on the vehicle is to take it to a shop and have the system flushed. They will disconnect a transmission line and pump new fluid in while the old fluid flows out. They basically do this until the fluid comes out "clean".
A system flush like this isn't normally needed and in many cases is a waste of money. It's an up-sell item many times and a decent profit center for a repair shop. It's kind of like using premium gas in a Cavalier. Yeah the premium gas works great, but you don't gain anything from using it.
Vinyl adds horsepower, right?
Old 03-16-2006, 08:57 PM
woscarr woscarr is offline
Cool Re: changing fluid in torque converter
Got mine done at a local oil lube shop.
They first dropped and cleaned the pan, obviously while doing this most of the trans oil comes out with the pan removal, except for torq covert. & cooler.
They replaced the filter and then flushed 10 liters through using the method cdr mentioned above.
On older vehicles they (whoever they is ?) recommend not doing the flush but doing it the way I got mine done. This way the pan is cleaned of debris and a fresh filter ensures nothing will get dislodged during the flush and end causing MAJOR problems soon after.
The filter replacement method is about twice as much as a flush but I think it's worth it.
Cheer's
