Old 03-13-2006, 09:54 PM
3000gtdj 3000gtdj is offline
Red face Engine Swaps wit a side of power
I have a 99 S10 and I wanna know what kind of engines are out there that can be a potential plat form to make big power or at least north of 400hp
Old 03-14-2006, 12:09 AM
OverBoardProject OverBoardProject is offline
Banned
Re: Engine Swaps wit a side of power
Get a 400 sbc, with thick cylinder walls at the bottom, and turn it into a hopped up 406. 400hp is easy then, but really more power than you need. I'd stick to 300 or less unless your planing on racing it.
If your truck has a 4.3L it'll bolt right up to the transmission, although you'll need some 2.8L motor mounts.
Old 03-14-2006, 11:27 AM
Question Re: Engine Swaps wit a side of power
1. Where can I get one and for how much
2. What kind of transmission should I get since I have a 4 cylinder
3. Forced induction Yes or No
Old 03-14-2006, 12:16 PM
Banned
Chevy started making 400 small blocks around 72 or 73, and they were used mostly in Van's. I believe some pickups as well.
A Google search will help you find what you want, but this article should give you an idea what the engine build involves
http://www.chevyhiperformance.com/te.../148_0306_406/
As for the transmission, I personally would use a Comaro transmission. It's up to you weather you use a 5 speed, or run an auto.
Old 03-14-2006, 04:26 PM
Banned
s10blazerman4x4 has a lot of the stuff for first gen V8 swaps
http://www.automotiveforums.com/vbul...=1#post3909829
A lot of it will fit on yours as well
