| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
eclipse bad rpm
my eclipse is not stable at rpm. after traveling for a few miles my car starts having up and downs at the rpm and sometimes it goes up to 2000 rpm on neutral what is the problem
Re: eclipse bad rpm
Might be your IAC sensor. That would be my first guess, also do you mean at idle? Also what year make and model do you drive?
95 Eclipse GS-T 6 bolt built block - shooting for 450 hp..very doable Currently: A lot, check progression thread - updated 3/27/10 Estimated completion date: Soon lol |
Re: eclipse bad rpm
Re: eclipse bad rpm
i drive a 95 gsx turbo. can this be cause of the over heat
Re: eclipse bad rpm
my car starts having the problem after driving and when it cools down it goes back to 1000 rpm
Re: eclipse bad rpm
Overheating is either a cooling problem (broken thermostat, air in the system, etc) or a blown head gasket.
What does IAC stand for? |
Re: eclipse bad rpm
It could be a boost leak, you can do a boost leak test via the instruction on vfaq.com (your new best friend) Is the car overheating? Or did it overheat?
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff. http://www.ratemydsm.com/member/ez1286/?member=ez1286
Re: eclipse bad rpm
i think it has some over heating problems cause today i saw mi car trowing a lot smoke from my engine and i tought it was normal but after i started loking at the other cars looking for smoke on their engines o found that it wasent normal. (today was a really cold day)
Re: eclipse bad rpm
Re: eclipse bad rpm
gm 3.5 maf, maft, fmic, emanage, profec e-01, wideband o2, 3" turbo bk exhaust +more little stuff, FOR SALE: 6bolt block w/ crank, caps, oil filt. housing, oil pump, and head all for $200 is all this for 200
Re: eclipse bad rpm
Dont judge overheating by the exhaust gas. Yes, it can diagnos (huge brainfart, spelling?) other problems, but just because you were making steam and everyone else wasnt during a cold day. Use your temperature guage to see if you are overheating. If white smoke was billowing from your exhaust, then I would worry about a headgasket, but other than that you should be fine.
EDIT: Read buddy, the parts for sale are clearly marked by the "For Sale." To eliminate any confusion, this is what he means: FOR SALE: 6bolt block w/ crank, caps, oil filt. housing, oil pump, and head all for $200 |
Re: eclipse bad rpm
Re: eclipse bad rpm
my rs do the same thing before, change spark plug and wire, with a bottle fuse injector cleaner, run for a while with high speed, the problem go away.
GM FOR LIFE !! NEW 1997 Camaro z28 6 speed illa never going back to import , but killa alway be nice to any DSM he saw ![]() looking for 2002 Trans Am LSX UPGRATE 2010 !! 97 Camaro Z28 95 camaro lt1 1992 Pontiac Firebird v6 auto -sold - Pony 1998 Mustang GT 4.6L Manual. Black 1995 Eagle Talon TSI AWD Turbo manual R.I.P 1994 Mitsubishi Eclipse Manual gray -Sold 1997 Mitsubishi Eclipse RS Auto White - Sold |
Re: eclipse bad rpm
Re: eclipse bad rpm
'92 3000gt SL Zoom Stage 1 Clutch Quote:
