Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 03-13-2006, 06:19 PM
MiSSeyHongThanh MiSSeyHongThanh is offline
Kenwood Deck Messed Up My Interior Lights..help!!!
I just recently put in a new Kenwood deck into my 2001 Honda Civic Coupe. Now my interior lights won't come on when I turn my lights on. I tried checking the fuse but none was blown. My gages won't light up anymore and the knobs on my heat/ac control won't light up either. What could be wrong?!? I had a Sony deck in there before and it worked just fine..could it be the Kenwood that is causing this problem?!?
Old 03-17-2006, 06:08 PM
Copytech99 Copytech99 is offline
Re: Kenwood Deck Messed Up My Interior Lights..help!!!
Remove any leads for illumination or dimmer connections hooked up during install. Check the "small lamps" fuse in the under-hood box.
Old 03-23-2006, 11:56 PM
my lights work now..thank you thank you a bunch...but my dimmer wire is not connected to anything. right now i have it taped to the metal harnest of my deck. is that normal?!?
Old 03-24-2006, 05:50 AM
I would leave it unhooked, But I would also isolate the end of that lead with some tape and just let it hang free.
Old 03-28-2006, 06:37 PM
if i don't leave it connected to the harnest, my interor lights won't stay on. It seems as though it needs to be connected to something metal..does that sound right?!? Do i need to connect the dimmer wire to anything else?!?
Old 03-28-2006, 09:56 PM
Can't be sure what wires and all is involved.
If this allows the lights to work then it should be o.k. BUT! keep a close check on dash lights for a while to make sure everything is normal.
Old 04-07-2006, 08:18 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
What wire are you talking about? Is it the red/black.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 04-15-2006, 09:37 PM
Audiobahn77 Audiobahn77 is offline
if your dimmer wire is touching any grounded metal...its going to short it out and will keep your interior lights from coming on or blow the fuse.
