Old 03-13-2006, 03:39 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Timing belt check... easiest way?
Hey guys, as many of you know, Mike's car wont start but it is getting gas, spark, and has runable compression. Next to check is timing. We're thinking it jumped, but didnt bend any valves. What is the best way to check the timing belt to see if the timing marks line up? Do we have to take off the wheel and wheel well black plastic shit, then take off the timing cover? Thanks guys.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 03-13-2006, 04:11 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Re: Timing belt check... easiest way?
Yeah you have to take off all that stuff to see where the crank is sitting when the cams are lined up. Oh, and the motor mount too to get the timing cover off. Which means you will have to find a way to support the engine. If it's AWD you can use the transfer case, just go slow and easy.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 03-13-2006, 06:26 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
You can take off the top timing belt cover peice and see if your cams line up, either crank it over and try to line it up, or turn it by hand at ur crank pulley. Clockwise only by the way.
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 03-13-2006, 08:35 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
on the cam gears there are dowels as all data call them, just go remove the cover and see if they line up they are right around the nut, mine are lined up... good luck
Old 03-13-2006, 09:28 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Make sure you turn them with your crank pulley, and check your belt.
If it skipped there might be damage to the belt. It's pretty easy to fuck those belts up.
This is what happened in the GSX i bought, well that and valves falling into the cylinders.
1991 GSX 2.3 Stroker
Old 03-13-2006, 09:45 PM
Thor06's Avatar
Jizzed In My Pants
Awesome, thanks guys, I appreciate the help.
Old 03-13-2006, 09:48 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
When was the last time he had his T-belt changed.
Old 03-13-2006, 10:00 PM
Thor06's Avatar
Jizzed In My Pants
The guy that had it before said it was done at 90k and it has ~106k now, but it doesnt look real great. There is a shiny section all the way around the belt on the engine side on the out side of the belt (the smooth side). There seem to be pits forming in that shiney section now. We are going to have a massive DSM work day/night in a few weeks, the timing belt is on the list for then. Since actually changing the timing belt doesnt require all that much more work than checking it, I think we are just going to buy a new timing belt and change it whether thats what is wrong or not.
Old 03-14-2006, 12:12 AM
Testiklees
Is the shiny stuff oil?
And just because the cams are lined up doesn't mean it isn't out of time. It would most likely skip at the crank anyway. You HAVE to look at the crank to see if it's really in time. And you have to remember to turn it over by hand several times before everything comes into phase.
I bought mine with bent valves. The cams would be in time with the oil, b -shaft but it would never line up with the crank. It was about 10 teeth off and the belt had no visible damage. Just 8 bent valves.
Tim
1990 Talon AWD
PTE SCM5031
Old 03-14-2006, 06:56 AM
Thor06's Avatar
Jizzed In My Pants
We thought it was oil, but it doesnt come off. I'll try to take some pictures.
Old 03-14-2006, 08:45 AM
kjewer1 kjewer1 is offline
AF - Advisor
A shiny part on the outsde of the belt tells me it was rubbing on something, most likely plastic.
YOu can avoid taking off the lower tbelt covers by using the timing mark on the crank pulley and timing marks on the cover (for setting base ignition timing). It's not terrible accurate in all cases, but it's certainly accurate enough to spot a belt thats off by a couple teeth or more. With that crank mark lined up and the dowel pins at 12 oclock (will happen every two rotations of the crank, since the cams turn at half speed), check the marks on the 3 and 9 oclock positions of the cam gears.
Checking the belt is easy, 10 minute job. Changing it requires retiming it and potentially retensioning it, with a lot more disassembly required... If it honestly looks good after a thorough check, I would move on to other things.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
