Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 03-13-2006, 03:29 PM
mizz_honda mizz_honda is offline
Engine Problems
I've had my Honda Prelude for 6 months now, and i'm noticing that whenever the car in left outside in extreme heat, the car won't start. Engine light comes on and if I have my sports button active, that flashes too.I was told that it could be the dizzy (not exactly sure what a dizzy is) that's causing the problem.
If anyone has had the same problem with their Honda's, please let me know thanks .
Old 03-13-2006, 06:13 PM
Gohan Ryu Gohan Ryu is offline
Re: Engine Problems
Does the engine crank at all? If it turns over but won't start it's probably your main relay -
"The main relay on Honda vehicles may often cause intermittent no-start conditions, especially when the weather gets hot." Replace it or you can search this website for info on how to fix it yourself (it involves re-soldering the contacts).
Dizzy is short for distributor.
Old 03-13-2006, 09:11 PM
Re: Engine Problems
Yeah it does turn over but as soon as it's about to start, it dies on me. Thanks on your advice Ryu.
Old 03-14-2006, 11:02 AM
kaimanson's Avatar
kaimanson kaimanson is offline
Cool Re: Engine Problems
main relay is your solution.
Old 03-27-2006, 01:14 PM
bladerunner212 bladerunner212 is offline
Re: Engine Problems
I had the same problem but its a easy fix.... turn your car on but dont start it and listen for a click in the left side of the dashboard. Try 2-3x....if u dont
hear a click its the main relay to fuel line 80.00 at the dealer
hoped it helped
Old 03-30-2006, 10:07 PM
sprat sprat is offline
Send a message via Yahoo to sprat
Re: Engine Problems
You didn't mention what year you had but I had two black 89 accords that has the distributor on top of the engine near the hood. When it got hot outside, it would do the same as yours did, crank but not start and then just shutoff. My mechanic told me that I need to open the hood for approx 10-15 mins, this would allow the engine compartment to cool down and then it would start!! sounds weird but it worked!!! there's something in the dist that causes this that Honda didnt tell us about!!! Hope this helps.
Old 04-03-2006, 11:40 AM
VTEC LOVER VTEC LOVER is offline
Banned
Re: Engine Problems
what year?
