Go Back   Automotive Forums .com Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 03-13-2006, 03:18 PM   #1
bwbumga1
Send a message via AIM to bwbumga1
right front abs sensor
My right front abs sensor has gone bad. Where do you guys suggest looking for a replacement. Im sure i can find on on the net cheaper than going to napa or auto zone...I talked to a buddy of mine who also drive an X and he said the part is around 100 bucks.
bwbumga1 is offline   Reply With Quote
Old 03-13-2006, 03:29 PM   #2
OffroadX
Send a message via AIM to OffroadX
Re: right front abs sensor
This isn't something you'll find aftermarket. Dealer-only part I'm sure...
When did you last check your spare tire's pressure?
OffroadX is offline   Reply With Quote
Old 11-20-2006, 03:11 AM   #3
[email protected]
i have the same problem. it's also killing my gas mileage. until that f#@*ing abs light comes on, the brakes will engage slightly. if you listen close you can hear it. nissan, in all it's infinite wisdom, decided it wasn't a "recallable" problem and decided to just do an upgrade. at nissan, parts and labor $400. the part is special order also, so chances are you aren't going to find it anywhere except nissan. good luck.
azzli69@hotmail.co is offline   Reply With Quote
Old 11-20-2006, 06:56 AM   #4
OffroadX
That's bull, a bad ABS sensor will not cause the brakes to engage slightly.
Old 11-21-2006, 10:19 AM   #5
chubbybubba1
Or have anything to do with bad fuel economy.
chubbybubba1 is offline   Reply With Quote
