Go Back   Automotive Forums Car Chat > Toyota > MR2/MR-S
Old 03-13-2006, 12:20 PM
2duce 2duce is offline
open d/p vs. exhaust
i have a 3" d/p and apexi gt spec exhaust. what is better to do? have the exhaust connect to the d/p or to run open d/p? witch will give me more power and witch is safer for the car.
Old 03-16-2006, 11:35 AM
JekylandHyde's Avatar
JekylandHyde JekylandHyde is offline
AF - Advisor
Re: open d/p vs. exhaust
If you have a typically designed MR2 downpipe it will be pointing toward the oil pan. Do you want a thousand degree flame pointing toward your oil pan?
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment
Old 03-20-2006, 11:41 AM
do u think that if i connect my apexi gt spec exhaust i will get better times
Old 08-13-2006, 10:45 PM
Kupop Kupop is offline
Send a message via AIM to Kupop
Open downpipe should give you better performance but as JekylandHyde said the downpipes for the MR2 point towards your oilpan.
Therefore the exhaust is "better" for the car. Also it will keep you out of tickets from making a lot of noise. I know in PA it is illegal to have a car without a muffler.
If you want the best solution; make a straight pipe for the car. Don't run an open downpipe, extend the exhaust out to the back of the car but just don't use any mufflers.
Old 11-19-2006, 11:31 AM
ECMgarrett ECMgarrett is offline
i agree with all of this
open DP will yeild better results, but with problems
just have an exhaust made for you that'll flow well, weigh nothing and keep you out of trouble
Xfighting the war on drugs a 1/4 mile at a timeX
93 mr2 turbo
94 rodeo
99 buell s3
76 HD shovelhead
