Old 03-13-2006, 11:23 AM
Earlsfat's Avatar
Earlsfat Earlsfat is offline
Cheesesteakoholic
Paint engine Q's
okokok...
Going to pull engine and paint it, etc.
1. What do i use to strip the old paint off???
2. Do I need to prime it???
3. Is multiple coats better than single coat???
4. How many cans of paint am I going to need???
Sanks.
Cheesesteak..... It does a body good.
"All you want to talk about is money, let's talk about love, and sex... forget love, let's just talk about sex. "
Old 03-13-2006, 12:39 PM
joker298 joker298 is offline
Re: Paint engine Q's
ok carb cleaner is best to clean it...no primer...and yea multi coats help....about 4 cans
Old 03-13-2006, 12:49 PM
ViperJ's Avatar
ViperJ ViperJ is offline
Send a message via MSN to ViperJ
1- I would agree carb cleaner or regular paint thinner (keeping away from any rubber lines)
2- Probably don't need to use primer, you will want the parts slightly rough so the paint will stick to them but that should be fine
3-You probably will want to light coats of paint then some type of sealer (I am not sure what its called but its like clear coat for high temps)
4-How much are you painting, is it the whole block and parts...
White 07 STI, Bone stock for now
Old 03-13-2006, 12:59 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
make sure the paint is high temp, i reccomend VHT
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 03-13-2006, 01:55 PM
KPot2004 KPot2004 is offline
i have always used primer, there is a company that makes some paint, its like a 4 step process, 1st can is cleaner, 2nd is primer, 3rd is paint, 4th is some sort of gloss coating. i have always done the first 3 steps, i have never really liked the high-gloss look for an engine...but yeah would def recommend the primer
Teamsters Local 332
1998 GMC Jimmy, 4.3 Vortec V6, 80,000 Miles, K&N Filter
1992 Chevrolet Camaro RS, 355 TPI, Under Construction
Old 03-13-2006, 01:56 PM
Earlsfat's Avatar
Cheesesteakoholic
I was going to use VHT simply because that's the only one in Jeg's and Summit. Yeah and I was wondering if the clear coat was warranted. I guess I oughtta put several coats of that on too, huh?
I'm going to paint the block, intake, and heads.... I think. At least that's what I'm leaning towards at this point.
BTW - Doesn't carb cleaner have some kind of light lubricant in it??? AND will it take the old paint off???
I'm going to redo the plumbing (most of it anyway) with braided lines so I'm not concerned about the rubber part so much, just whatever is going to give me the best results. BUT, will the carb cleaner or paint thinner eat anything else that I need to be aware of?
Thanks guys.
Old 03-13-2006, 01:59 PM
Earlsfat's Avatar
Cheesesteakoholic
Good point Kpot, I'm gonna find out if they have a sealer that's not a high gloss finish. It'd be hard to tell at a glance if you have anything leaking if it looks all shiny all the time.
Old 03-13-2006, 02:18 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Media blasting would be my first choice for clean up.
Old 03-13-2006, 02:40 PM
Earlsfat's Avatar
Cheesesteakoholic
Have a small sand blaster that hooks up to my compressor... same thing??? Just make sure all the holes are covered up before doing it right???
Old 03-13-2006, 04:12 PM
wrightz28's Avatar
Yeah something like that, i'd just do it before taking the heads off. Then a good power washing once apart with warm soapy water.
