Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-13-2006, 10:04 AM
impalass impalass is offline
Unhappy 94 Honda SI redline problems
Hi people!!! here is my problem... I got a honda SI, stock D16Z6. I replace the water pump and timing belt. I align the lower pulley with the marks on the cover and the top pulley with the "top" on top and align the marks on the side. Engine start fine, but now it don't reach 7500RPM redline. It just go to 6500RPM I used a timing light and adjust the timing to 16* BTDC and still have the same results. Any IDEAS what is wrong????
Old 03-14-2006, 12:06 AM
blitzcivic's Avatar
blitzcivic blitzcivic is offline
Re: 94 Honda SI redline problems
if there seems to be a loss of power your timing is retard you maybe off a tooth. if you hear your valves ticking your to advanced.
1993 HONDA CIVIC EX
BLITZ FRNT M3 SIDE BLACK WIDOW REAR
JSP TERMINATOR WING
17' MOTEGI SUPER SILVER RIMS
D16Z SOHC 1.6 VTEC
SKUNK2 INTAKE MANIFOLD
CROME TUNED ECU
B&M FUEL REG
DSM 450CC INJ.
MSD BLASTER COIL
APC 9MM WIRE
GREDDY BACKCAT EX
T25 CUSTOM TURBO KIT @ 7PSI
TUBULAR MANIFOLD
AIR TO AIR INTERCOOLER
ALCOHOL INJECTION
18002 TURBO MILES AT 218002 MILES GOING 140MPH FINALLY WENT
BUT, STILL GOT ME HOME
