Wierd Transmission Problem
Any wisdom available on this? 93 AS AWD works fine, except that in first or reverse, it's like driving with the emergency brake on. And no, the emergency brake is not on.
Re: Wierd Transmission Problem
I'm not sure if you are still having these problems .... but we had a similar problem with our 1993. We thought it was also our transmission. We even had it confirmed when we took it into the rinky-dinky shop down the street. We were all set to junk it when my husband had a thought....
Check the rear yolk. Sure enough it was low. It took almost a whole thing of gear dope! Never had the problem again! We just included this in our regular checks of fluid levels. Hope this helps. It sure was better than having to buy a new transmission or new vehicle. It only costs a couple dollars!!!!!!!!! Good Luck! Karen |
Cant get the plug out of yolk it is so tight any suggestions?
Perhaps I am too late.... and I'm sorry if so .... But I will leave this intormation out there in case someone else needs it as well....
The yoke is very hard to get off. It is actually made to come off with a 3/8" rachet. (That's without any socket, of course). But be careful.... It could easily strip. If this happens, I'd suggest using an allen wrench, large enough that you could pound in. This way you can have a tight fit to get it off. Otherwise, you'll have to take it into a shop to have them get it. Good luck with that! Karen |
Well your not to late it could help us with our van. Thanks for your information!!!
Please check the date of the last post in the thread. If it is longer than 3 months from the current date it is considered inactive,and should not be resurrected .
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
