Old 03-13-2006, 08:59 AM
scootin scootin is offline
Exclamation i smell gas!
after driving i can smell gas. i can find no leaks,othrwise runs great.
can also smell gas when i put one window down. all info apprieciated
95 s10 blazer
108576 mi.
4.6 liter
Old 03-13-2006, 11:19 AM
Ultrashock's Avatar
Ultrashock Ultrashock is offline
Re: i smell gas!
Be a little more specific......... Do some looking around while you have the engine running and try and find where the smell is coming from
I didnt know they made a 283 for a 95 blazer
92 S10 Blazer Sport
4.3l Vortec V6 (W)
275,000 miles
Jasper engine, Rebuilt tranny + rearend
04 Pontiac Grand Prix GT
43,000 miles
Old 03-13-2006, 11:21 AM
drdd's Avatar
drdd drdd is offline
Re: i smell gas!
95 s10 blazer
108576 mi.
4.6 liter
you got CPI? have you replaced it and nut kit?
also, do you 'top off' the tank when you fill up?
Old 03-13-2006, 11:48 AM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: i smell gas!
id bet money that ur cpi and/or nut kit is bad. can u tell wher the smell is coming from? mine had a strong gas smell in the intake and coming from the tail pipe. take off the IMTV, look for leaks and take a wif. if u can see clean areas or if there is a strong smell of gas in the monifold, the fuel regulator or nut kit is probably bad.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 03-13-2006, 01:25 PM
drdd's Avatar
Re: i smell gas!
95 s10 blazer
108576 mi.
4.6 liter
have you noticed a change in mpg ?
Old 03-13-2006, 07:52 PM
Re: i smell gas!
correction 4.3 liter.
it's hard to locate the soarce of smell,i can smell it at the rear of the truck and under the hood. this is my wifes car, but i drove it today , and the idle seems a little fast but it does drop back to normal sometimes. i don't know about milage as i don't drive it but maybe 3 times a year and she doesn't keep up w/ that sort of thing.
Old 03-13-2006, 09:32 PM
ZL1power69's Avatar
GM S-Series Mod
Re: i smell gas!
the longer u drive like that, the more damage is being done. tell her to start keep track of the mpg (miles gone on tank/gallons put in). if it winds up getting about 10mpg, strongly consider a cpi/nut kit replacement, which is like $300 in parts so i would suggest removing the upper manifold (takes all of 10min) to visually inspect the parts. if u see any clean areas, u probably have a leak. turn the key on to pressurize the system and u should be able to spot any leaks. hope this helps u.
Low 11 sec sleeper
My Cardomain
