Old 07-04-2002, 12:23 PM
sohcvtecrx sohcvtecrx is offline
Gauges not working and funny sounds.
Hey guys Ive got a problem. The other day my turn signals, clock, heat gauge, tachometer, and fuel gauge all went out at the same time. Does anyone have a clue as to what this could be? Maybe a short in the wiring or just a fuse? And on another subject a couple weeks ago someone tried to steal my car (luckily they were stopped). Ever since my car has been making some very strange noises. The closest thing I can compare them to would be a modem dialing up. It sounds almost identical. Could this be vacuum hoses? I really dont feel like taking this thing to a mechanic just to charge me an arm and a leg for a diagnosis. Any help would be greatly appreciated.
Thanks
Old 07-04-2002, 06:47 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
the other things arent all connected on the same fuse, but you can still check them under the dash, as for the wierd noises, when do they occur?
shifting, idle, etc???
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 07-04-2002, 07:48 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
i dunno if this helps but on my last 90 Dx...i heard a similair noise. a week later i noticed my tach, gas gauge, and something else quit working and my check engine light came on. it was just a loose speedo cable. have you checked yours?
ami
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 07-04-2002, 08:54 PM
The noises usually occur only at idle. I didnt check the speedo cable but I will since you had a similar problem. The only thing different is the fact that the noise in my car happened after the gauges stopped working, but I will definitely check it out. Thanks for the help guys.
