Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 03-12-2006, 11:31 PM
Rain333x Rain333x is offline
Removing calipers on 01 sunfire
Hi, can anyone let me know how to remove the calipers on an 01 sunfire? I need to replace the pads. Do you need a specialty tool? The only bolts I see are the 2 behind the seals and the 1 holding the cable. Thanks for any help.
Old 03-13-2006, 02:47 AM
muff34 muff34 is offline
Re: Removing calipers on 01 sunfire
You can get an adapter for these bolts that will fit on a rachet.Take the two bolts out of caliper. I am guessing that the bolt you are referring too holding the " cable " is the hyraulic hose. Do not take the hydraulic hose on caliper off ,do not even loosen it unless you want to bleed the caliper later.you will have to take the cap off master cylinder to take any pressure off of caliper to make it easier to remove, also you will have to compress caliper piston so you can put new shoes on and get back in position. You should also clean and lubricate cailper bolts (guide pins ) before you put it back together, There is a specific type of silicone grease / lube for these bolts (pins) it is Not an ordinary silicone.
Life Is A Highway ,Enjoy The Ride
Old 03-13-2006, 07:47 AM
Thanks a lot, that's all I needed to know. Have a good one.
Old 03-14-2006, 02:28 AM
No problem , You Have a good one also
