Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 03-12-2006, 11:55 PM
sweetal sweetal is offline
99 Crown Vic P71 idle/cruise issues
Hello all, I'm new to this forum and new to CV ownership. I drove my car over 1800 miles home from place of purchase. About halfway home I developed a problem of the car having to be cranked several times before it started (like carb cars when they were flooded). Also, the idle would go up and down for a while while in park and when I changed gears it surged for a second then went up and down idle. Any thoughts??
Also, my cruise and cig adapter doesn't work. Any thoughts on that?
The car runs fine once it gets started. And if its left for a long time it will start right up.
Thanks in advance for any help!
Alan
Old 03-17-2006, 03:09 PM
ModMech's Avatar
ModMech ModMech is offline
Re: 99 Crown Vic P71 idle/cruise issues
I believe that the hard starting and rolling idle are both due to the same thing, EITHER a bad Idle Air Control (IAC), or a vacuum leak. Either is possible, and would cause the symptoms you describe.
Old 03-17-2006, 05:10 PM
Thanks ModMech! Now, can you or anyone else tell me what an IAC looks like and where exactly its located?? I found where the MAP is!! Wahoo! Now help me (mechanically challenged) locate the IAC in my 99 P71.
Thanks in advance for the help, otherwise it would cost me $75/hr or more--yikes!
Old 03-17-2006, 07:15 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
The IAC is located top rear center of engine. It is sorta stuffed under a couple of tubes. It is a silver tubular thing that is held on by two 8mm bolts. There is also a wiring connection and a hose about an inch in diameter going to it.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
