Old 03-12-2006, 10:21 PM
put_101 put_101 is offline
frustrating fuel filter
ok i got a new fuel filter to put on my jeep and we followed the fuel line all the way to the motor but there is no fuel filter any where we could see...now the jeep is starting to choke out at 25 to 30 mph and i dont know what the deal is but am assuming it is because no fuel filter....how and where do i install my fuel filter so i can get y jeep running top notch again?
Old 03-13-2006, 12:22 AM
thinmints thinmints is offline
Re: frustrating fuel filter
a little more info is needed year of jeep, 6 or 4 cyclinder
Old 03-13-2006, 09:25 AM
Saudade's Avatar
Saudade Saudade is offline
If your problem was caused by a lack of a fuel filter, then you likely have some other fuel components that are now clogged and/or dirty. Simplying adding a fuel filter will not clean these.
The location depends on your year/model, as Thinmints says.
Old 03-13-2006, 09:53 AM
Ray H Ray H is offline
As others have said, its hard to tell without knowing what year Jeep you have.
If the filter isnt along the inside of the frame rail on the drivers side, just in front of the rear axle, then its in the tank and a real PITA to change.
Old 03-13-2006, 02:59 PM
sorry i forgot to mention that. it is a 86 jeep cherokee 4wd with a v6 engine
Old 03-17-2006, 11:21 AM
joe8918's Avatar
joe8918 joe8918 is offline
I have a '96 Jeep Cherokee 4x4 with a 4.0 inline 6. The fuel filter is just about above the rear axle on the driver side of the vehicle. Be ready to collect becuase it dumped probably 1/2 gallon of fuel on me when I changed mine. Good luck!
Old 03-17-2006, 05:50 PM
vamc's Avatar
vamc vamc is offline
its in frount of the rear driverside wheel. its up on the fraim of the jeep.
Old 03-21-2006, 07:22 PM
wwwildman wwwildman is offline
The fuel filter is located inside the fuel inlet nut at the carburetor. It's made of either pleated paper or porous bronze and cannot be cleaned or reused. You will need two wrenches, flare nut wrenches if available.
Old 03-22-2006, 08:56 PM
vamc's Avatar
The fuel filter in in back of the car, in frount of the rear tire. Right? Or are we talking about 2 different things?
Old 03-23-2006, 05:59 PM
According to the haynes manual it is in the place i quoted, but it is possible that there is a bigger, normal one at the location that you said also.
Old 03-24-2006, 11:52 AM
vamc's Avatar
I thought there was only one, but i WILL take your word on that.
Old 03-24-2006, 04:20 PM
dave92cherokee's Avatar
dave92cherokee dave92cherokee is offline
Easy way to solve this. Put_101 is the engine in your jeep carb. or fuel inj.? If it's carb then the fuel filter is inside the air cleaner housing that sits on top of the carb. If it's fuel inj. then the filter is on the inside of the driver side frame rail above the rear axle.
Old 03-25-2006, 05:34 PM
vamc's Avatar
Sounds good to me.
