Old 03-12-2006, 10:08 PM
Tims_240's Avatar
Tims_240 Tims_240 is offline
tranny wont go above second
as stated above, my 91 camaro (5.7L) wont go above second gear, but will go into 1st and reverse.. i was just wondering if anyone could tell me what is wrong with it.
do you think the cheapest way to solve the problem would be to buy a new tranny?
how much would can i expect to pay for this type of tranny?
thanks guys..
-tim
mods list: t3/t04e, iap oil lines, iap i-c piping, xspower i-c, z32 mafs, enthalpy tuned ecu, 615cc injectors, s14 tomei fuel pump, blitz DD bov, tial 38mm w/g, BD exhuast mani./downpipe, Spec StageIII clutch .
.s13 power.
power estimate at ~ 270 whp @ 11 psi.
Old 03-12-2006, 10:16 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Re: tranny wont go above second
Goto a junkyard and find one there from a v8 camaro..
Old 03-12-2006, 10:25 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
are you low on fluid? have you checked the linkage? it may require a rebuild, or you can get a used one... but see if the linkage is lose, and make sure you're not low on tranny fluid
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 03-12-2006, 10:26 PM
ok i forgot to ask, do you mean you put it into drive and it won't shift out of 1st? or you put it in drive and nothing happens, but it works when you move the shifter into the 1 position?
Old 03-12-2006, 10:27 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
hey tims, i thought in a eairlyer post you said it was the shift pack or someting like that?
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 03-12-2006, 10:42 PM
Tims_240's Avatar
i put it into D (drive) and it will go into first, then shift into second, and it wont go past that. (nice car btw)
im truthfully not sure what the problem is, i will check the fluid level, but i wouldnt see why it would go into first and second and then stop.
thanks for the great response time, you guys are very helpful.
.s13 power.
Old 03-12-2006, 10:44 PM
Tims_240's Avatar
oh yea, im not totally sure of what linkage you are talking about, if you could explain that would be awesome!
-tim
.s13 power.
Old 03-13-2006, 12:31 AM
get underneath the car, and on the drivers side of the transmission is a place where a cable coming from your shifter lever goes to, check the cable for being loose, and see if the gear selecter that it moves is able to be moved freely
Old 03-13-2006, 12:34 AM
Is eating.
If it was the linkage it wouldnt allow him to get into drive.. atleast for me it went like that.
Old 03-13-2006, 06:18 AM
Tims_240's Avatar
I just dont understand why it wont go above second, i wish i knew how an automatic tranny worked so i could source the problem, but i dont. I think i will just go ahead and buy a tranny from a junkyard, im getting one for around 250 - 300, so its not too bad, i can install myself too.
thanks alot for the helpful suggestions.
-tim
.s13 power.
Old 03-13-2006, 03:11 PM
malletslinger's Avatar
malletslinger malletslinger is offline
You have a confusing problem with your trans...If the trans needed a rebuild, then it would shift to third...but it would be like it had shifted to neutral...I would think it was the shift control, not the mechanical parts of the trans itself.
