Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 03-12-2006, 09:35 PM
honda67337 honda67337 is offline
Unhappy 99 Honda Si IDLE PROBLEM PLEASE HELP!
My 99 honda civic si idles up and down while its parked. After I have driven it a while, while i am at a stop light it starts idle up and down so fast it sounds like its cutting out. When I try to slowly take off it falls on its face!!! If I floor it, its fine.... I just replaced the Idle Air Control Valve and I thought it fixed it, but its doing it again. The code is coming up as Idle Air Circuit Malfunction!!!!
Can anyone help? Someone said check for vac leaks but I dont know where to start with that!!
( by the way, it didnt start doing this until i sprayed cleaner into my throttle body, i was trying to clean out the carbon)
ANY HELP WOULD BE APPRECIATED THANKS!!!
Old 03-16-2006, 01:59 AM
hierro0430 hierro0430 is offline
Re: 99 Honda Si IDLE PROBLEM PLEASE HELP!
well. you might hurted one of the sensors on the intake manifold. i had the same problem with my civic 95. i replaced the map censor. it is located on top of the throttle body . check if one of the vac sensor on the back of the manifold was loose or broken, but i almost sure is the map sensor.
Old 03-16-2006, 02:01 AM
sorry. i think it is too late.
