Old 03-12-2006, 06:39 PM
SONNYVG SONNYVG is offline
Diff Ecu Wit Diff Motor
I HAVE A D16Z6 ALL I WANT TO DO IS REDLINE MORE THAN 7200RPM, SO THAN SHOULD I PUT A B16 ECU OBD1 RUNNING A D16Z6 AND WILL IT WORK, OR IS THERE SOMETING ELSE I CAN DO??????????????????????????I NEED TO KNOW A.S.A.P.
Old 03-12-2006, 08:08 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Diff Ecu Wit Diff Motor
Reving it higher won't do anything for power gains. The stock rev limiter is there for a reason; you don't make power past it.
Old 03-12-2006, 10:04 PM
eurobeaner's Avatar
eurobeaner eurobeaner is offline
Send a message via MSN to eurobeaner
if you really felt like blowin your motor, you could buy a cheap $20 chip you put into your ecu that moves rev limit to like 9k and removes top speed limiter..... USE AT YOUR OWN RISK... i would never do it, i dont feel like having a $20 thing that does absolutely nothing for power, blow my motor...
95 Civic EX
H&R sport springs
KYB AGX Struts
Energy Suspension Poly Bushings
15" black VSR's on nitto NT450 not-so extreme performance 205/50/15
CAI
http://www.cardomain.com/ride/2489240/1
Old 03-13-2006, 11:39 AM
hany's Avatar
hany hany is offline
sorry for wrong answer
MY ENGLISH IS NOT PERFECT. sorry for that
1992 CIVIC 4DOOR ULTRA BLUE TURBO -SOLD
1996 CIVIC 4DOOR EUROPIAN VTEC LS
2003 CIVIC LXI
1999 GOLF 4 1400 CC
Old 03-13-2006, 12:43 PM
CivicSpoon's Avatar
There is no Spoon
Originally Posted by hany
if you need more power you can use high pressure fuel pump with FMU with exhust with new cluch , you will find very big changes without damageing the motor . and your red line still as 7200 but you will reach the 7200 very fast than the old.
Not true at all. You may gain a couple hp (nothing noticable by the human body), but you'll also go through gas like crazy and probably bog the engine (especially if it's stock). The stock ECU is capable of compensating enough fuel for basic bolt-ons. More fuel does not mean more power. Engines like to be almost lean to make the most power out of them (throughout their powerband), not way too rich. And FMU's are garbage for Hondas. Even for forced induction cars, they're just not reliable or even good compared to real engine management systems. If you want real power gains past basic bolt-ons, you either have to build the engine up (higher compression pistons and cams) or add forced induction; there is NO way around it. Simply adding more fuel, raising the redline, adding one of those cheap $20 e-bay chips, cheap e-bay resistors, etc; are all bs "techniques" that aren't worth a damn.
Old 03-13-2006, 12:44 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
i'm just wondering if you've learned anything at all with the time you spend here and all of the questions you ask.
Empty Pockets Racing Member #1
Old 03-13-2006, 01:00 PM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
god I love bad advice
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 03-13-2006, 04:44 PM
hany's Avatar
sorry for you all i thought he is using turbo. sorry for that . because i faces som diffecult in my turbo system so my mind went to turbo sorry for that again .
2003 CIVIC LXI
1999 GOLF 4 1400 CC
Old 04-27-2006, 03:16 PM
93civicsiracer 93civicsiracer is offline
i beg to differ. i know of a b16a all motor chipped running all day close to redlining at 9grand and it runs like a beast. he shifts at 81/2 but when he shift at 9 or 10 and pop the clutch the car gets a burst of wheel spin as u shift into the next get there improving ur time. on top of that the chip gave a noticable amount of power. i dont nkow what kind of racer u or any one else here is but i feel ever bit of my power in my car. i notice things like a knock sensor if its un plugged or my distributor timing moves (only has one bolt holding till later today.), when the engine needs a valve adjustment (me and my furl faut over that one and i won), my airfilter being dirty, even my oil being dirty. i can tell all ofthis just by the sound and feel of the car as a go threw each gear..... if u can sit there and say i dont feel any of that then its because theres nothing wrong with ur car. if any one begs to differ then speak up and i can prove it to u.
Old 04-27-2006, 03:56 PM
CivicSpoon's Avatar
There is no Spoon
When you shift later, you're going to be at a higher rpm in the next gear, than you would if you shifted sooner. But you're still losing power by reving those extra rpms, when you should have shifted sooner to keep you in your powerband. Reving higher on a stock engine only puts you past your optimum power band and puts unecessary strain on your engine. You're better off shifting when you're supposed to and making up those extra rpm (that you'd gain from shifting late) in the next gear, at least those rpms will be in your powerband. Is that all motor B16a you're talking about modified (higher compression pistons, and or cams) or stock? That will make a big difference. But being able to notice when something is wrong with your car is completely different than adding a modification to the car and being able to feel the difference. And I do beg to differ, so let's see some proof. How about a dyno sheet of a stock engine reving to the stock limiter and one of it reving to 9K. I guarentee the power will drop off far before reaching 9K. A butt dyno doesn't mean anything. People swear they feel big power gains from new exhaust systems, when in reality it's the sound that's just confusing their senses.
Old 04-27-2006, 11:28 PM
fiberglasscivic's Avatar
fiberglasscivic fiberglasscivic is offline
Send a message via AIM to fiberglasscivic Send a message via Yahoo to fiberglasscivic
Well said CivicSpoon! I hate to say it but until you can cough up the dyno printouts with a video to show that all you did was add some ebay piggyback that removes the top speed and revlimiter then there's no point in saying you can feel the difference in a the hp gain. You may be able to tell every little thing that's wrong with your engine and that's great. Not everyone is so able to stay in tune with their car. That's doesn't make you a good racer or a bad one. Maybe a damn good mechanic but definatly not a good racer.
Yeah I wish I could say all that about myself and my car but I don't care as long as when it comes to crunch time, I can fix it.
AF COMMUNITY GUIDELINES
